소개
Chip ID for the Samsung Galaxy S22 Ultra smartphone.
Check out our Samsung Galaxy S22 teardowns for more details.
Many thanks to our community member CChin for his contributions!
동영상 개요
IC Identification Pt. 1:
Qualcomm SM8450 Snapdragon 8 Gen 1 Octa-Core Processor layered under a Samsung K3LK7K70BM-BGCP 8 GB Mobile LPDDR5 SDRAM Memory
Samsung KLUDG4UHDC-B0E1 128 GB NAND Flash Memory (UFS 3.1)
Wacom WEZ02 Digitizer Controller
Maxim MAX77705C Power Management
Renesas P9320S Wireless Power Transceiver
NXP Semiconductor PCA9468 Battery Charger
Cirrus Logic CS35L40 Audio Amplifier
IC Identification, pt. 2:
Cirrus Logic CS40L26 Haptic Driver
Qualcomm PMR735A Power Management
Qualcomm PM3003 Power Management
Diodes Incorporated AP7340D-30FS4-7 150 mA / 3.0 V LDO Regulator
Diodes Incorporated AP7340D-33FS4-7 150 mA / 3.3 V LDO Regulator
Knowles MEMS Microphone
Qualcomm PMK8450 ? Clock Generator
IC Identification Pt. 3:
Qualcomm SDR735 RF Transceiver
Qualcomm SMR546 RF Transceiver
NXP Semiconductor SN220U NFC Controller w/ Secure Element
NXP Semiconductor SR100T Ultra-Wideband SoC
NXP Semiconductor BGU8103 GPS / GLONASS / Galileo / BeiDou Low Noise Amplifier
Qualcomm QET5100 Envelope Tracker
IC Identification pt. 1:
Qualcomm PM8350 Power Management
Qualcomm PM8350C Power Management
Qualcomm PM8450 Power Management
Samsung S2MPB02 Power Management
Samsung S2MPBA3 Power Management
Goertek MEMS Microphone
IC Identification pt. 3:
Broadcom BCM4389 Wi-Fi 6E & Bluetooth 5.0
Broadcom AFEM-9146 Front-End Module
Skyworks SKY58083-11 Front-End Module
Qualcomm QPM6815 Front-End Module
Qualcomm QDM3572 Antenna Switch Module
Qorvo 2389 RF Power Amplifier (likely)
Qorvo 5389 RF Power Amplifier (likely)
댓글 12개
Where is the esim located?
on my ( Prime Day 22) Samsung S S22 Ultra , all 3 side buttons have recessed into body of phone. I finally got it to turn on but accessing the buttons moving forward will require a tiny flat head screw driver.. Paper clip slipped , my 1 fingernail finally turned it on so I'd find a solution. I've had mobile phones since 1996 and have never seen anything like this before . I had a Bumper case on back, had trouble removing it. I hadnt noticed the situation till tonight
what shd I do? I'm not "sucking on my phone".
My power button has just fallen off. Can't find a green one to replace it myself, probably because they don't make an s22 ultra in green for the Chinese market, and that's where all the power buttons are located. So red (burgundy) and black are my choices; incidentally, the volume rocker is included with the power butto Which accent would look better on the s22 ultra in green? Or would the s22 plus or s22 buttons be interchangeable?
Glenn -
please i need help with my 22 ultra, it fell and the screen wont display anything, it is not broken, the phone still works and i hear sound and receive calls but the display is blank, now the screen was changed and it still does not display anything, please what do i do, important doc on this phone i cant connect it to pc because i need to enter password n allow access. any advice? my email = frankasiboje@gmail.com
I need for Samsung s22 ultra U3004 IC Transceiver SM-G908E
How can I order ?
Es divertido reparador utilizar el conocimiento de tal eminencia para germinar una experiencia q,nunca has tenido y te arriesgas guao gracias maestro ok
would the "Qualcomm QDM3572 Antenna Switch Module" be considered as the "network chip"?
Me puede ayudar alguien, que me diga quales son los chips que tengo que cambiar para cambiar la memoria de una placa base a otra y cuales son los pasos porfavor ?
