주요 콘텐츠로 건너뛰기
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy S22 Ultra 수리는 자사의 서비스 설명서를 사용하세요.
  1. Samsung Galaxy S22 Ultra Chip ID, Main Board Side 1: 1 단계, 이미지 2개 중 1개 Samsung Galaxy S22 Ultra Chip ID, Main Board Side 1: 1 단계, 이미지 2개 중 2개
    • IC Identification Pt. 1:
    • Qualcomm SM8450 Snapdragon 8 Gen 1 Octa-Core Processor layered under a Samsung K3LK7K70BM-BGCP 8 GB Mobile LPDDR5 SDRAM Memory
    • Samsung KLUDG4UHDC-B0E1 128 GB NAND Flash Memory (UFS 3.1)
    • Wacom WEZ02 Digitizer Controller
    • Maxim MAX77705C Power Management
    • Renesas P9320S Wireless Power Transceiver
    • NXP Semiconductor PCA9468 Battery Charger
    • Cirrus Logic CS35L40 Audio Amplifier
  2. Samsung Galaxy S22 Ultra Chip ID: 2 단계, 이미지 1개 중 1개
    • IC Identification, pt. 2:
    • Cirrus Logic CS40L26 Haptic Driver
    • Qualcomm PMR735A Power Management
    • Qualcomm PM3003 Power Management
    • Diodes Incorporated AP7340D-30FS4-7 150 mA / 3.0 V LDO Regulator
    • Diodes Incorporated AP7340D-33FS4-7 150 mA / 3.3 V LDO Regulator
    • Knowles MEMS Microphone
    • Qualcomm PMK8450 ? Clock Generator
  3. Samsung Galaxy S22 Ultra Chip ID: 3 단계, 이미지 1개 중 1개
    • IC Identification Pt. 3:
    • Qualcomm SDR735 RF Transceiver
    • Qualcomm SMR546 RF Transceiver
    • NXP Semiconductor SN220U NFC Controller w/ Secure Element
    • NXP Semiconductor SR100T Ultra-Wideband SoC
    • NXP Semiconductor BGU8103 GPS / GLONASS / Galileo / BeiDou Low Noise Amplifier
    • Qualcomm QET5100 Envelope Tracker
  4. Samsung Galaxy S22 Ultra Chip ID: 4 단계, 이미지 1개 중 1개
    • IC Identification pt. 4 (sensors):
    • Austria Microelectronics Ambient Light/Color/Gesture/Proximity Sensor
    • STMicroelectronics 6-Axis Accelerometer & Gyroscope
  5. Samsung Galaxy S22 Ultra Chip ID, Main Board Side 2: 5 단계, 이미지 2개 중 1개 Samsung Galaxy S22 Ultra Chip ID, Main Board Side 2: 5 단계, 이미지 2개 중 2개
    • IC Identification pt. 1:
    • Qualcomm PM8350 Power Management
    • Qualcomm PM8350C Power Management
    • Qualcomm PM8450 Power Management
    • Samsung S2MPB02 Power Management
    • Samsung S2MPBA3 Power Management
    • Goertek MEMS Microphone
  6. Samsung Galaxy S22 Ultra Chip ID: 6 단계, 이미지 1개 중 1개
    • IC Identification, pt 2:
    • Vishay DG2730 2-Port DPDT Analog Switch
  7. Samsung Galaxy S22 Ultra Chip ID: 7 단계, 이미지 1개 중 1개
    • IC Identification pt. 3:
    • Broadcom BCM4389 Wi-Fi 6E & Bluetooth 5.0
    • Broadcom AFEM-9146 Front-End Module
    • Skyworks SKY58083-11 Front-End Module
    • Qualcomm QPM6815 Front-End Module
    • Qualcomm QDM3572 Antenna Switch Module
    • Qorvo 2389 RF Power Amplifier (likely)
    • Qorvo 5389 RF Power Amplifier (likely)
    Qorvo 2389 is WIFI 2G FEM from Qorvo, and Qorvo 5389 is WIFI 5G FEM from Qorvo.
    xiajinggai - 답글
  8. Samsung Galaxy S22 Ultra Chip ID: 8 단계, 이미지 1개 중 1개
    • IC Identification pt. 4 (Sensors):
    • AKM Semiconductor 3-Axis Electronic Compass
    • STMicroelectronics Pressure Sensor
댓글 12개
Is there a way to contact the person that did this teardown? It would be great if I can ask about additional devices on the S22 smartphone.
Jae - 답글
Where is the esim located?
Buncha Stocks - 답글
on my ( Prime Day 22) Samsung S S22 Ultra , all 3 side buttons have recessed into body of phone. I finally got it to turn on but accessing the buttons moving forward will require a tiny flat head screw driver.. Paper clip slipped , my 1 fingernail finally turned it on so I'd find a solution. I've had mobile phones since 1996 and have never seen anything like this before . I had a Bumper case on back, had trouble removing it. I hadnt noticed the situation till tonight
Holly VH, Snoop&Fuzzy - 답글
what shd I do? I'm not "sucking on my phone".
My power button has just fallen off. Can't find a green one to replace it myself, probably because they don't make an s22 ultra in green for the Chinese market, and that's where all the power buttons are located. So red (burgundy) and black are my choices; incidentally, the volume rocker is included with the power butto Which accent would look better on the s22 ultra in green? Or would the s22 plus or s22 buttons be interchangeable?
Glenn -
please i need help with my 22 ultra, it fell and the screen wont display anything, it is not broken, the phone still works and i hear sound and receive calls but the display is blank, now the screen was changed and it still does not display anything, please what do i do, important doc on this phone i cant connect it to pc because i need to enter password n allow access. any advice? my email = frankasiboje@gmail.com
frank Steel - 답글
I need for Samsung s22 ultra U3004 IC Transceiver SM-G908E
How can I order ?
Jahongir Mamadiyorov - 답글
Es divertido reparador utilizar el conocimiento de tal eminencia para germinar una experiencia q,nunca has tenido y te arriesgas guao gracias maestro ok
ANDRES MARTINEZ RENTERIA - 답글
A friend gifted a s22ultra to me 😁😁😁!!!! He said I could have it if I could unlock it 😒! It’s screen locked any ideas??
Stewart - 답글
would the "Qualcomm QDM3572 Antenna Switch Module" be considered as the "network chip"?
Elliott Jackson - 답글
Me puede ayudar alguien, que me diga quales son los chips que tengo que cambiar para cambiar la memoria de una placa base a otra y cuales son los pasos porfavor ?
raduniko kio - 답글
عندي جهاز اس22 الترا عند توصيل الشاحن تظهر المقاومة الحرارية
قمت بتغيير ايسي الشحن والمقاومات الحرارية التي بجواره
ونفس الشي
وعند تشغيله والدخول للتطبيقات يطفي الجهاز
Takal - 답글
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 157
지난 30일: 606
전체 시간: 44,090
