이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Heat an iOpener and apply it to a long edge of the phone for about two minutes.
Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
Lift on the suction cup and insert an opening pick under the rear glass.
Once you have the pick firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
Slide the opening pick up along the side of the phone, separating the adhesive.
Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
이 단계에 사용된 도구:Tweezers$4.99-
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
다른 26명이 해당 안내서를 완성하였습니다.
댓글 4개
this didn’t address the camera lens
They have a separate article for the camera lens.
Is it waterproof with new adhesive film? Isn't it better to use a liquid glue like B-7000 or T-7000?
Ist es wasserdicht mit neuer Klebefolie? Ist es nicht besser, einen flüssigen Kleber wie B-7000 oder T-7000 zu verwenden?
Hi Tobias,
The phone will not be “waterproof” with new adhesive, as that requires a special press. It will be water resistant to a certain degree if you clean the mating surfaces and apply either adhesive or B7000.
