소개
Drop your S8? Keep it in the same pocket as your keys?
Chances are the glass back is already shattered. Use this guide to replace the back panel glass on the Samsung Galaxy S8.
If your replacement part does not come with adhesive mounted on it, you will also need to purchase adhesive for the rear glass and the fingerprint reader. You can buy pre-cut adhesive, or thin high-bond tape.
필요한 것
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
이 단계에 사용된 도구:Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
If you're installing a new rear glass panel, you'll also need to transfer the fingerprint sensor to your new rear glass panel as follows:
Reheat an iOpener and apply it to the fingerprint sensor mounted to the rear glass.
Push the fingerprint sensor off of its adhesive from the outside of the glass.
If the sensor is stubborn, gently slide an opening pick under the plastic backing to loosen the adhesive before pushing.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
After you've completed the repair, follow this guide to test your repair.
다른 129명이 해당 안내서를 완성하였습니다.
댓글 17개
No. After the adhesive is removed, your water resistance is as gone as your warranty.
after the rear panel is removed? ... no...
Great tutorial, simple and straight to the point. My type of learning.
If I could add just one little thing….
I myself would have loved if you would have touched on replacing the fingerprint scanner ribbon when replacing the back glass. , I learned
None the less, you gave me knowledge and I thank you…
