주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S3 Display Replacement
필요한 것
  1. Samsung Galaxy Tab S3 Display Replacement, Display: 1 단계, 이미지 1/1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Display Replacement: 2 단계, 이미지 1/1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Display Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Display Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab S3 Display Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab S3 Display Replacement: 4 단계, 이미지 3/3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: 5 단계, 이미지 1/2 Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: 5 단계, 이미지 2/2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
결론
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
다른 7명이 해당 안내서를 완성하였습니다.
Jelly Romero
회원 가입일: 04/19/18
322 평판
안내서 1개 작성함
Cal Poly, Team S22-G4, Maness Spring 2018 Cal Poly, Team S22-G4, Maness Spring 2018 회원
CPSU-MANESS-S18S22G4
5 회원들
안내서 15개 작성하였습니다
댓글 5개
Thank you so much, It helped me so much.
MRxROBOT - 답글
What if the digitizer is ok and only the glass cover is cracked
stargazer_jbl - 답글
if you need more adhesive what is the right type to buy? Want to have some on hand before I open my S3 up.
jnorr - 답글
If my screen freezing exactly half, can that be the connection cable damaged.? It's look like it happens every time I touch or hold the corner where the volume and power buttons are. Never dropped it.
Lena Clark - 답글
I also have the same issue
How your issue was resolved.
Ashwin -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 36
30일 전: 169
전체 시간: 26,516
