주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Victory 4G Screen Replacement
필요한 것
  1. Samsung Galaxy Victory 4G Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Victory 4G Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Victory 4G Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Place the phone face down. Ensure that the side with the display screen is not facing you.
    • Locate the back door and slide open.
    • Remove the battery.
    댓글 쓰기
  2. Samsung Galaxy Victory 4G Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
    댓글 쓰기
  3. Samsung Galaxy Victory 4G Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
    댓글 쓰기
  4. Samsung Galaxy Victory 4G Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove one Phillips 3.93 mm screw from the bottom center of the phone.
    댓글 쓰기
  5. Samsung Galaxy Victory 4G Screen Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Victory 4G Screen Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Victory 4G Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully disconnect the 3 labeled ribbons. To remove, place tool under the ribbon and pull slowly to avoid tearing.
    댓글 쓰기
  6. Samsung Galaxy Victory 4G Screen Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy Victory 4G Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled ribbon and pull gently to detach the ribbon cable from the motherboard.
    • At this point, the motherboard should be completely detached from the rest of the phone.
    댓글 쓰기
  7. Samsung Galaxy Victory 4G Screen Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Victory 4G Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Next, detach the labeled cable . Pull gently on the black gate and use a tool to pull out the cable.
    • Detach the labeled digitizer chip by gently prying a tool under the chip and pulling it up and out.
    댓글 쓰기
  8. Samsung Galaxy Victory 4G Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Heat iOpener in microwave for one minute on the highest power setting. Let the iOpener sit on the device for about 90 seconds. This step is necessary to loosen the glue under the display screen. Be careful, the glue is very sticky!
    댓글 쓰기
  9. Samsung Galaxy Victory 4G Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Place the suction cup on the screen. Make sure not to place the cup on the cracked area.
    댓글 쓰기
  10. Samsung Galaxy Victory 4G Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Pull gently to detach the screen.
    • Once detached, gently remove the ribbon from the shown slot. At this point, you can replace the cracked screen with a new one.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Zhao
회원 가입일: 09/23/14
266 평판
안내서 2개를 작성함
USF Tampa, Team 15-3, Remmell Fall 2014 USF Tampa, Team 15-3, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G3
4 회원들
안내서 6개를 작성함
2가이드 댓글
Info correct - replaced my screen no prob.
George Kuch - 답글 공유
This phone doesn't have sim card slot?
Jephthah Afari - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 40
전체 시간: 2,346
