주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy View Camera Replacement
필요한 것
    1. Samsung Galaxy View Camera Replacement, Kickstand: 1 단계, 이미지 1개 중 1개
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
      댓글 쓰기
    2. Samsung Galaxy View Camera Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy View Camera Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy View Camera Replacement: 2 단계, 이미지 3개 중 3개
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
      댓글 쓰기
    1. Samsung Galaxy View Camera Replacement, Battery: 3 단계, 이미지 2개 중 1개 Samsung Galaxy View Camera Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Check the device is completely turned off.
      • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
      댓글 쓰기
    2. Samsung Galaxy View Camera Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy View Camera Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy View Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
      댓글 쓰기
    3. Samsung Galaxy View Camera Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy View Camera Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy View Camera Replacement: 5 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
      • Insert the metal spudger within the opening.
      • Move the metal spudger down the seam, prying the back panel open as you go.
      • Once a large enough opening is made, pry the entire back panel off with your hand.
      • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
      댓글 쓰기
    4. Samsung Galaxy View Camera Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy View Camera Replacement: 6 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
      댓글 쓰기
    5. Samsung Galaxy View Camera Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy View Camera Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy View Camera Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
      • Remove the battery from the device.
      댓글 쓰기
    1. Samsung Galaxy View Camera Replacement, Camera: 8 단계, 이미지 3개 중 1개 Samsung Galaxy View Camera Replacement, Camera: 8 단계, 이미지 3개 중 2개 Samsung Galaxy View Camera Replacement, Camera: 8 단계, 이미지 3개 중 3개
      • Place the plastic opening tool underneath the blue press-fit connector which is touching the green circuit board at the bottom of the device.
      • Pry upwards with the plastic opening tool to disconnect the press-fit connector.
      • Remove the camera by carefully gripping the press-fit connector and pulling upwards.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jordan Thayer
회원 가입일: 10/06/16
535 평판
안내서 2개를 작성함
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G5
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
전체 시간: 1,402
