주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy View Kickstand Replacement
필요한 것
    1. Samsung Galaxy View Kickstand Replacement, Kickstand: 1 단계, 이미지 1개 중 1개
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
      댓글 쓰기
    2. Samsung Galaxy View Kickstand Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy View Kickstand Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy View Kickstand Replacement: 2 단계, 이미지 3개 중 3개
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jordan Thayer
회원 가입일: 10/06/16
535 평판
안내서 2개를 작성함
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G5
4 회원들
안내서 24개를 작성함
15가이드 댓글
Where do u buy a replacement kickstand
Bethann Stokes - 답글 공유
The only thing I could find was a broken one on eBay for parts ......
cindylou73 - 답글 공유
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 48
전체 시간: 9,617
