주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy View Motherboard Replacement
필요한 것
    1. Samsung Galaxy View Motherboard Replacement, Kickstand: 1 단계, 이미지 1개 중 1개
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
      댓글 쓰기
    2. Samsung Galaxy View Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy View Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy View Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
      댓글 쓰기
    1. Samsung Galaxy View Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 1개 Samsung Galaxy View Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Check the device is completely turned off.
      • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
      댓글 쓰기
    2. Samsung Galaxy View Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy View Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy View Motherboard Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
      댓글 쓰기
    3. Samsung Galaxy View Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy View Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy View Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
      • Insert the metal spudger within the opening.
      • Move the metal spudger down the seam, prying the back panel open as you go.
      • Once a large enough opening is made, pry the entire back panel off with your hand.
      • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
      댓글 쓰기
    4. Samsung Galaxy View Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy View Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
      댓글 쓰기
    5. Samsung Galaxy View Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy View Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy View Motherboard Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
      • Remove the battery from the device.
      댓글 쓰기
    1. Samsung Galaxy View Motherboard Replacement, Speakers: 8 단계, 이미지 3개 중 1개 Samsung Galaxy View Motherboard Replacement, Speakers: 8 단계, 이미지 3개 중 2개 Samsung Galaxy View Motherboard Replacement, Speakers: 8 단계, 이미지 3개 중 3개
      • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
      • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
      댓글 쓰기
    2. Samsung Galaxy View Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy View Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
      • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
      댓글 쓰기
    1. Samsung Galaxy View Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Samsung Galaxy View Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
      • Insert the plastic opening tool beneath the orange press-fit connector attached to the bottom left side of the motherboard and use a leverage motion to pry the connector from the board.
      • Repeat the above step for the other two orange press-fit connectors attached on the bottom left side of the motherboard.
      댓글 쓰기
    2. Samsung Galaxy View Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Samsung Galaxy View Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to pry up on the blue antenna cable connector near the right edge of the motherboard.
      • Repeat the above for the black antenna cable connector positioned next to the blue wire.
      댓글 쓰기
    3. Samsung Galaxy View Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Samsung Galaxy View Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Samsung Galaxy View Motherboard Replacement: 12 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove the nine 3 mm screws around the motherboard.
      • There is a metal bracket beneath four of the screws on the right side of motherboard. This bracket will also be removed during this step.
      댓글 쓰기
    4. Samsung Galaxy View Motherboard Replacement: 13 단계, 이미지 1개 중 1개
      • Lift the motherboard straight up to remove it from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Amberley Powell
회원 가입일: 10/06/16
790 평판
안내서 2개를 작성함
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G5
4 회원들
안내서 12개를 작성함
7가이드 댓글
Hi… Where can I get a replacement motherboard for a Samsung galaxy view? I need one.
Ryan Mitchell - 답글 공유
DITTO that I need a new mother board as well. Where can we purchase it?
Lori Marr - 답글 공유
Hello I need the charger plugin and wire harness replacement parts. there tiny heres a screen shot of what is needed. If anyone knows where please posts info in reply thank you
[img]https://i.imgur.com/QMgrXkh.jpg[/img]
wildcar - 답글 공유
where can you find a replacement motherboard. seems like all you can you is buy a used one off ebay.
chiming tse - 답글 공유
where can you buy a replacement motherboard. seems like only way is to buy a used unit off ebay.
chiming tse - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 45
전체 시간: 7,905
