주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Gear Live Battery Replacement
필요한 것
    1. Samsung Gear Live Battery Replacement, Lay the watch face-down: 1 단계, 이미지 1개 중 1개
      • Lay the watch face-down on a flat, stable surface.
      댓글 쓰기
    2. Samsung Gear Live Battery Replacement, Remove the holding pin: 2 단계, 이미지 1개 중 1개
      • Press the watchband down against the work surface.
      • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
      댓글 쓰기
    3. Samsung Gear Live Battery Replacement, Remove the watchband: 3 단계, 이미지 1개 중 1개
      • With the spring-loaded pin pressed in, the watch band should release easily.
      • Gently pull the band away from the body of the watch.
      • Repeat steps 2 and 3 for the opposite side.
      댓글 쓰기
    1. Samsung Gear Live Battery Replacement, Locate the four screws: 4 단계, 이미지 1개 중 1개
      • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
      댓글 쓰기
    2. Samsung Gear Live Battery Replacement, Remove the 4 screws: 5 단계, 이미지 1개 중 1개
      • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
      댓글 쓰기
    3. Samsung Gear Live Battery Replacement, Pry off the back of the watch.: 6 단계, 이미지 1개 중 1개
      • Gently work the plastic opening tool under the top edge of the watch’s back cover.
      댓글 쓰기
    4. Samsung Gear Live Battery Replacement, Lift off the back cover: 7 단계, 이미지 2개 중 1개 Samsung Gear Live Battery Replacement, Lift off the back cover: 7 단계, 이미지 2개 중 2개
      • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
      댓글 쓰기
    5. Samsung Gear Live Battery Replacement, Set both halves of the watch aside: 8 단계, 이미지 1개 중 1개
      • Lay both halves of the watch body assembly face down (with internal components facing up).
      댓글 쓰기
    1. Samsung Gear Live Battery Replacement, Locate the battery: 9 단계, 이미지 1개 중 1개
      • Locate the battery on the back half of the disassembled watch body. It is rectangular in shape and located just above the window for the heart monitor.
      댓글 쓰기
    2. Samsung Gear Live Battery Replacement, Locate the battery contacts: 10 단계, 이미지 1개 중 1개
      • Locate the battery’s electrical contacts. They are located next to the heart rate monitor. They roughly form a “+” shape.
      • Using the plastic opening tool, gently pry the contacts away from the plastic channel in which they fit.
      댓글 쓰기
    3. Samsung Gear Live Battery Replacement, Pry out the battery: 11 단계, 이미지 1개 중 1개
      • Gently work the plastic opening tool under the battery.
      • Using the plastic opening tool, gently pry the battery up.
      • If replacing the battery, please dispose of it properly. Do not throw the battery in the trash. Contact your local municipality for locations which accept lithium-ion batteries for disposal or recycling.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Keith Cooper
회원 가입일: 09/25/14
1,265 평판
안내서 6개를 작성함
USF Tampa, Team 1-7, Brown Fall 2014 USF Tampa, Team 1-7, Brown Fall 2014 회원
USFT-BROWN-F14S1G7
3 회원들
안내서 7개를 작성함
7가이드 댓글
Indicate the tools needed.
Dan Brown - 답글 공유
Indicate screw measurements to nearest mm.
Dan Brown - 답글 공유
This is neat and helpful, but where do I find a replacement battery?
joshthehappy - 답글 공유
Where can I purchase these batteries?
chad flores - 답글 공유
I purchased my battery on eBay.
Jay - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 38
전체 시간: 10,101
