주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Gear S2 Battery Replacement
필요한 것
    1. Samsung Gear S2 Battery Replacement, Watch Strap: 1 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement, Watch Strap: 1 단계, 이미지 2개 중 2개
      • Flip the watch over so that the face is down.
      • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
      • Remember to turn off the watch to avoid being shocked.
      댓글 쓰기
    2. Samsung Gear S2 Battery Replacement: 2 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Using your finger, push forward on the release while pulling up on the strap.
      • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
      댓글 쓰기
    3. Samsung Gear S2 Battery Replacement: 3 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Repeat the procedure from step 2 for the other strap.
      댓글 쓰기
    1. Samsung Gear S2 Battery Replacement, Back: 4 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement, Back: 4 단계, 이미지 2개 중 2개
      • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
      • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
      댓글 쓰기
    1. Samsung Gear S2 Battery Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
      • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
      댓글 쓰기
    2. Samsung Gear S2 Battery Replacement: 6 단계, 이미지 3개 중 1개 Samsung Gear S2 Battery Replacement: 6 단계, 이미지 3개 중 2개 Samsung Gear S2 Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Using a spudger, pry up the three cables.
      댓글 쓰기
    3. Samsung Gear S2 Battery Replacement: 7 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement: 7 단계, 이미지 2개 중 2개
      • Using the flat end of a spudger, pry up the motherboard.
      • Make sure the cable is fed through the hole to avoid damaging it.
      • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
      댓글 쓰기
    1. Samsung Gear S2 Battery Replacement, Battery: 8 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement, Battery: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using tweezers, lift the battery casing.
      • Make sure the cables are fed through their gaps to avoid damaging them.
      댓글 쓰기
    2. Samsung Gear S2 Battery Replacement: 9 단계, 이미지 2개 중 1개 Samsung Gear S2 Battery Replacement: 9 단계, 이미지 2개 중 2개
      • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
      • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 103명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Jacob Baldwin
회원 가입일: 02/20/17
3,459 평판
안내서 5개를 작성함
USF Tampa, Team S2-G3, Sullivan Spring 2017 USF Tampa, Team S2-G3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G3
3 회원들
안내서 23개를 작성함
39가이드 댓글
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - 답글 공유
A reference to the battery part number would be great.
Harold Turner - 답글 공유
Very good job and very easy
JEAN PIERRE - 답글 공유
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 47
지난 30일: 170
전체 시간: 162,205
