주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Gravity TXT Screen Replacement
필요한 것
  1. Samsung Gravity TXT Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Gravity TXT Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    댓글 쓰기
  2. Samsung Gravity TXT Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the back cover away from the main body of the phone.
    댓글 쓰기
  3. Samsung Gravity TXT Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    댓글 쓰기
  4. Samsung Gravity TXT Screen Replacement, SIM Card: 4 단계, 이미지 3개 중 1개 Samsung Gravity TXT Screen Replacement, SIM Card: 4 단계, 이미지 3개 중 2개 Samsung Gravity TXT Screen Replacement, SIM Card: 4 단계, 이미지 3개 중 3개
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
    댓글 쓰기
  5. Samsung Gravity TXT Screen Replacement, microSD Card: 5 단계, 이미지 3개 중 1개 Samsung Gravity TXT Screen Replacement, microSD Card: 5 단계, 이미지 3개 중 2개 Samsung Gravity TXT Screen Replacement, microSD Card: 5 단계, 이미지 3개 중 3개
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
    댓글 쓰기
  6. Samsung Gravity TXT Screen Replacement, Plastic Back Frame: 6 단계, 이미지 1개 중 1개
    • Remove the six 3 mm #00 Phillips screws in the plastic back frame.
    댓글 쓰기
  7. Samsung Gravity TXT Screen Replacement: 7 단계, 이미지 3개 중 1개 Samsung Gravity TXT Screen Replacement: 7 단계, 이미지 3개 중 2개 Samsung Gravity TXT Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the keyboard out.
    • Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
    • Starting at the bottom of the keyboard is recommended.
    • Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
    • You will have to slide the keyboard back in to separate the back frame from the top have of the keyboard slider.
    • Lift the plastic back frame away.
    댓글 쓰기
  8. Samsung Gravity TXT Screen Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
    • Do not try to pull the motherboad out just yet. The display data cable needs to be disconnected from the motherboad first.
    댓글 쓰기
  9. Samsung Gravity TXT Screen Replacement: 9 단계, 이미지 3개 중 1개 Samsung Gravity TXT Screen Replacement: 9 단계, 이미지 3개 중 2개 Samsung Gravity TXT Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Use your finger nail to disconnect the display data cable from the motherboard.
    댓글 쓰기
  10. Samsung Gravity TXT Screen Replacement: 10 단계, 이미지 2개 중 1개 Samsung Gravity TXT Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully lift the main motherboard assembly away from the front panel.
    댓글 쓰기
  11. Samsung Gravity TXT Screen Replacement, Keyboard: 11 단계, 이미지 1개 중 1개
    • Take the keyboard off of the phone.
    댓글 쓰기
  12. Samsung Gravity TXT Screen Replacement, Screen: 12 단계, 이미지 3개 중 1개 Samsung Gravity TXT Screen Replacement, Screen: 12 단계, 이미지 3개 중 2개 Samsung Gravity TXT Screen Replacement, Screen: 12 단계, 이미지 3개 중 3개
    • Lift the ribbon off the plastic inner frame.
    • You may have to warm the adhesive using an iOpener to avoid damaging the ribbon.
    • Remove the six 1.2 mm #00 screws from the inner plastic frame.
    • Slide the ribbon through the slot on the inner frame while pulling the frame away.
    댓글 쓰기
  13. Samsung Gravity TXT Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the four 2.4 mm #00 Phillips screws.
    댓글 쓰기
  14. Samsung Gravity TXT Screen Replacement: 14 단계, 이미지 3개 중 1개 Samsung Gravity TXT Screen Replacement: 14 단계, 이미지 3개 중 2개 Samsung Gravity TXT Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Use a opening pick to separate the plastic back casing from the front of the phone by running it along the seam between the two.
    • Lift casing slightly away while sliding the ribbon through the slot in the casing.
    댓글 쓰기
  15. Samsung Gravity TXT Screen Replacement: 15 단계, 이미지 2개 중 1개 Samsung Gravity TXT Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Use a spudger to get underneath and remove the call speaker.
    댓글 쓰기
  16. Samsung Gravity TXT Screen Replacement: 16 단계, 이미지 2개 중 1개 Samsung Gravity TXT Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the plastic adhesive sheet to expose the ribbon cables
    • The use of an iOpener may be needed to soften the eadhesive
    • Use your finger or a spudger to pull the screen ribbon out of the connector
    댓글 쓰기
  17. Samsung Gravity TXT Screen Replacement: 17 단계, 이미지 3개 중 1개 Samsung Gravity TXT Screen Replacement: 17 단계, 이미지 3개 중 2개 Samsung Gravity TXT Screen Replacement: 17 단계, 이미지 3개 중 3개
    • Use a Jimmy to separate the screen from the rest of the phone
    • You may need to heat the perimeter of the screen with an iOpener to soften the adhesive.
    • Lift the screen away
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Sieverding
회원 가입일: 07/07/15
186 평판
안내서 1개를 작성함
IUPUI, Team 1-1, Renguette SU 2015 IUPUI, Team 1-1, Renguette SU 2015 회원
IUPUI-RENGUETTE-SU15S1G1
5 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 1,219
