주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Gusto 2 Keypad Replacement
필요한 것
  1. Samsung Gusto 2 Keypad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the phone screen down like this.
    댓글 쓰기
  2. Samsung Gusto 2 Keypad Replacement: 2 단계, 이미지 2개 중 1개 Samsung Gusto 2 Keypad Replacement: 2 단계, 이미지 2개 중 2개
    • Find the little slit on the side of the phone and stick your fingernail in between the slit and push your thumb upwards towards your hand.
    • Look at the next picture for the slit.
    댓글 쓰기
  3. Samsung Gusto 2 Keypad Replacement: 3 단계, 이미지 3개 중 1개 Samsung Gusto 2 Keypad Replacement: 3 단계, 이미지 3개 중 2개 Samsung Gusto 2 Keypad Replacement: 3 단계, 이미지 3개 중 3개
    • Pop out the battery by placing your finger in between the open slit.
    댓글 쓰기
  4. Samsung Gusto 2 Keypad Replacement, Keypad: 4 단계, 이미지 2개 중 1개 Samsung Gusto 2 Keypad Replacement, Keypad: 4 단계, 이미지 2개 중 2개
    • Identify the screws as follows and take your screwdriver and unscrew these screws.
    • The screws highlighted in the picture do not need to come out, in fact it is really hard to remove them. Simply unscrewing them will loosen the back of the phone.
    댓글 쓰기
  5. Samsung Gusto 2 Keypad Replacement: 5 단계, 이미지 1개 중 1개
    • Once you have unscrewed the four screws, take your spudger/plastic opening tool and wedge it in the back of the phone as shown in the picture.
    • Find a very thin crevice which seems to run around the phone itself and assertively wedge the spudger into the crevice.
    • Once you have successfully inserted the spudger follow through by sliding the spudger assertively around the phone frame.
    • Apply moderate force while trying to wedge the tool in.
    댓글 쓰기
  6. Samsung Gusto 2 Keypad Replacement: 6 단계, 이미지 3개 중 1개 Samsung Gusto 2 Keypad Replacement: 6 단계, 이미지 3개 중 2개 Samsung Gusto 2 Keypad Replacement: 6 단계, 이미지 3개 중 3개
    • The back should now be exposed like the first picture after the case was removed.
    • Flip open the phone, main screen facing up.
    • Push the keypad and slide it out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Michael Huang
회원 가입일: 03/30/15
403 평판
안내서 3개를 작성함
UMass Dartmouth, Team 2-5, Shastany Spring 2015 UMass Dartmouth, Team 2-5, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S2G5
3 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 19
전체 시간: 795
