주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung HMX-W200 Battery Replacement
필요한 것
    1. Samsung HMX-W200 Battery Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Samsung HMX-W200 Battery Replacement: 2 단계, 이미지 3개 중 1개 Samsung HMX-W200 Battery Replacement: 2 단계, 이미지 3개 중 2개 Samsung HMX-W200 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
      • Make sure to separate all the corners before removing the red casing.
      댓글 쓰기
    3. Samsung HMX-W200 Battery Replacement: 3 단계, 이미지 2개 중 1개 Samsung HMX-W200 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
      댓글 쓰기
    4. Samsung HMX-W200 Battery Replacement: 4 단계, 이미지 2개 중 1개 Samsung HMX-W200 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
      • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
      댓글 쓰기
    5. Samsung HMX-W200 Battery Replacement: 5 단계, 이미지 2개 중 1개 Samsung HMX-W200 Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
      댓글 쓰기
    6. Samsung HMX-W200 Battery Replacement: 6 단계, 이미지 2개 중 1개 Samsung HMX-W200 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
      댓글 쓰기
    7. Samsung HMX-W200 Battery Replacement: 7 단계, 이미지 3개 중 1개 Samsung HMX-W200 Battery Replacement: 7 단계, 이미지 3개 중 2개 Samsung HMX-W200 Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
      댓글 쓰기
    8. Samsung HMX-W200 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Separate the front and back casing.
      댓글 쓰기
    1. Samsung HMX-W200 Battery Replacement, Battery: 9 단계, 이미지 2개 중 1개 Samsung HMX-W200 Battery Replacement, Battery: 9 단계, 이미지 2개 중 2개
      • Remove the four 4.00mm screws holding the battery brace using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Samsung HMX-W200 Battery Replacement: 10 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, lift the copper tab holding the battery brace in place.
      댓글 쓰기
    3. Samsung HMX-W200 Battery Replacement: 11 단계, 이미지 2개 중 1개 Samsung HMX-W200 Battery Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the battery brace and battery from the camera casing.
      • Remove the old battery from the brace and place the new one.
      • Your battery might be held to the brace by a copper tape. If so, you'll need to peel the tape away to remove it. This tape does not affect the battery's operation in any way, so it is safe to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ashton Esparza
회원 가입일: 10/04/16
101 평판
안내서 1개를 작성함
USF Tampa, Team 3-6, Sullivan Fall 2016 USF Tampa, Team 3-6, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S3G6
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 35
전체 시간: 1,447
