주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Impression Antenna Replacement
필요한 것
  1. Samsung Impression Antenna Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    댓글 쓰기
  2. Samsung Impression Antenna Replacement: 2 단계, 이미지 2개 중 1개 Samsung Impression Antenna Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    댓글 쓰기
  3. Samsung Impression Antenna Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    댓글 쓰기
  4. Samsung Impression Antenna Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    댓글 쓰기
  5. Samsung Impression Antenna Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    댓글 쓰기
  6. Samsung Impression Antenna Replacement: 6 단계, 이미지 2개 중 1개 Samsung Impression Antenna Replacement: 6 단계, 이미지 2개 중 2개
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    댓글 쓰기
  7. Samsung Impression Antenna Replacement, Antenna: 7 단계, 이미지 2개 중 1개 Samsung Impression Antenna Replacement, Antenna: 7 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
    • The antenna assembly will snap off.
    댓글 쓰기
결론
To replace the antenna and reassemble your device, follow the steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Saul Villatoro
회원 가입일: 04/25/11
260 평판
안내서 7개를 작성함
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 회원
CPSU-REGAN-S11S8G10
4 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 32
전체 시간: 3,298
