주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Impression Camera Replacement
필요한 것
    1. Samsung Impression Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      댓글 쓰기
    2. Samsung Impression Camera Replacement: 2 단계, 이미지 2개 중 1개 Samsung Impression Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      댓글 쓰기
    1. Samsung Impression Camera Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      댓글 쓰기
    2. Samsung Impression Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      댓글 쓰기
    1. Samsung Impression Camera Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      댓글 쓰기
    2. Samsung Impression Camera Replacement: 6 단계, 이미지 2개 중 1개 Samsung Impression Camera Replacement: 6 단계, 이미지 2개 중 2개
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      댓글 쓰기
    1. Samsung Impression Camera Replacement, Camera: 7 단계, 이미지 2개 중 1개 Samsung Impression Camera Replacement, Camera: 7 단계, 이미지 2개 중 2개
      • Turn the circuit board over.
      • The bottom of the camera will have a gold ribbon coming out of it which attaches to the circuit board.
      • Pull upwards on the blue rectangle where the gold ribbon ends. This will remove the camera from the circuit board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Saul Villatoro
회원 가입일: 04/25/11
260 평판
안내서 7개를 작성함
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 회원
CPSU-REGAN-S11S8G10
4 회원들
안내서 99개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 1,928
