주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Impression Keyboard Replacement
필요한 것
    1. Samsung Impression Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      댓글 쓰기
    2. Samsung Impression Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung Impression Keyboard Replacement: 2 단계, 이미지 2개 중 2개
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      댓글 쓰기
    1. Samsung Impression Keyboard Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      댓글 쓰기
    2. Samsung Impression Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      댓글 쓰기
    1. Samsung Impression Keyboard Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      댓글 쓰기
    2. Samsung Impression Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Samsung Impression Keyboard Replacement: 6 단계, 이미지 2개 중 2개
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      댓글 쓰기
    1. Samsung Impression Keyboard Replacement, Antenna: 7 단계, 이미지 2개 중 1개 Samsung Impression Keyboard Replacement, Antenna: 7 단계, 이미지 2개 중 2개
      • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
      • The antenna assembly will snap off.
      댓글 쓰기
    1. Samsung Impression Keyboard Replacement, Keyboard: 8 단계, 이미지 1개 중 1개
      • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
      • The screws are 2.7mm in length.
      • The bottom black end cap will snap out.
      댓글 쓰기
    2. Samsung Impression Keyboard Replacement: 9 단계, 이미지 2개 중 1개 Samsung Impression Keyboard Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
      • Separate the silver plate and phone frame (fig. 2).
      댓글 쓰기
    3. Samsung Impression Keyboard Replacement: 10 단계, 이미지 1개 중 1개
      • The silver piece you are left with is the physical keyboard assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Ross McKelvie
회원 가입일: 04/18/11
196 평판
안내서 4개를 작성함
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 회원
CPSU-REGAN-S11S8G10
4 회원들
안내서 132개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 26
전체 시간: 2,718
