주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Impression LCD Replacement
필요한 것
  1. Samsung Impression LCD Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    댓글 쓰기
  2. Samsung Impression LCD Replacement: 2 단계, 이미지 2개 중 1개 Samsung Impression LCD Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    댓글 쓰기
  3. Samsung Impression LCD Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    댓글 쓰기
  4. Samsung Impression LCD Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    댓글 쓰기
  5. Samsung Impression LCD Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    댓글 쓰기
  6. Samsung Impression LCD Replacement: 6 단계, 이미지 2개 중 1개 Samsung Impression LCD Replacement: 6 단계, 이미지 2개 중 2개
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    댓글 쓰기
  7. Samsung Impression LCD Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
    댓글 쓰기
  8. Samsung Impression LCD Replacement: 8 단계, 이미지 2개 중 1개 Samsung Impression LCD Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
    • Separate the silver plate and phone frame (fig. 2).
    댓글 쓰기
  9. Samsung Impression LCD Replacement: 9 단계, 이미지 1개 중 1개
    • The silver piece you are left with is the physical keyboard assembly.
    댓글 쓰기
  10. Samsung Impression LCD Replacement, LCD Flex Cable: 10 단계, 이미지 2개 중 1개 Samsung Impression LCD Replacement, LCD Flex Cable: 10 단계, 이미지 2개 중 2개
    • Remove the 3 screws holding down the flex cable.
    • The two screws on the black frame are 2.0 mm in length.
    • The top right screw that goes through the circle port on the flex cable is 2.3 mm.
    • Remove the keyboard slider frame. The flex cable should be exposed, but not free.
    댓글 쓰기
  11. Samsung Impression LCD Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the four 3.5 mm outer screws.
    댓글 쓰기
  12. Samsung Impression LCD Replacement: 12 단계, 이미지 3개 중 1개 Samsung Impression LCD Replacement: 12 단계, 이미지 3개 중 2개 Samsung Impression LCD Replacement: 12 단계, 이미지 3개 중 3개
    • Slide the phone apart and remove the 3.5 mm screw on the top middle (fig. 1).
    • Remove the outer shell by prying the edges off with your fingers or a small screwdriver (fig. 2).
    • The device will now be in two pieces (fig. 3).
    댓글 쓰기
  13. Samsung Impression LCD Replacement: 13 단계, 이미지 2개 중 1개 Samsung Impression LCD Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the tab underneath the blue tape and gently pull the flex cable (fig. 1).
    • The flex cable will now be completely free (fig. 2).
    댓글 쓰기
  14. Samsung Impression LCD Replacement, Ear Speaker: 14 단계, 이미지 1개 중 1개
    • Remove the 2.3 mm screw.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
    댓글 쓰기
  15. Samsung Impression LCD Replacement, LCD: 15 단계, 이미지 2개 중 1개 Samsung Impression LCD Replacement, LCD: 15 단계, 이미지 2개 중 2개
    • Lift the remaining two tabs and free their respective ribbon cables.
    • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Saul Villatoro
회원 가입일: 04/25/11
260 평판
안내서 7개를 작성함
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 회원
CPSU-REGAN-S11S8G10
4 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 34
전체 시간: 4,844
