주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Instinct Camera Replacement
필요한 것
    1. Samsung Instinct Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Apply pressure to the back cover and slide it forward towards the camera.
      • Lift the back cover off the phone.
      댓글 쓰기
    2. Samsung Instinct Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Holding the phone firmly, use the notches to grip and lift up the battery.
      댓글 쓰기
    1. Samsung Instinct Camera Replacement, Back Case: 3 단계, 이미지 1개 중 1개
      • Remove the four 4.45mm screws at the corners of the phone.
      댓글 쓰기
    2. Samsung Instinct Camera Replacement: 4 단계, 이미지 2개 중 1개 Samsung Instinct Camera Replacement: 4 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to unhinge the locks around the edges of the phone.
      • Do not worry about the inner components of the phone; they are not connected to this case.
      댓글 쓰기
    3. Samsung Instinct Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the casing off of the phone.
      댓글 쓰기
    1. Samsung Instinct Camera Replacement, Antenna: 6 단계, 이미지 1개 중 1개
      • With the screws removed, locate the antenna.
      댓글 쓰기
    2. Samsung Instinct Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
      댓글 쓰기
    3. Samsung Instinct Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
      댓글 쓰기
    4. Samsung Instinct Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Gently lift up on the antenna and remove it from the back of the device.
      댓글 쓰기
    1. Samsung Instinct Camera Replacement, Front Case: 10 단계, 이미지 1개 중 1개
      • Remove the two 3.50mm screws connecting the motherboard to the case.
      댓글 쓰기
    2. Samsung Instinct Camera Replacement: 11 단계, 이미지 3개 중 1개 Samsung Instinct Camera Replacement: 11 단계, 이미지 3개 중 2개 Samsung Instinct Camera Replacement: 11 단계, 이미지 3개 중 3개
      • Use the plastic opener tool to detach the three ribbons on the motherboard.
      댓글 쓰기
    3. Samsung Instinct Camera Replacement: 12 단계, 이미지 1개 중 1개
      • Lift out the top right ribbon from its slot on the motherboard.
      댓글 쓰기
    4. Samsung Instinct Camera Replacement: 13 단계, 이미지 2개 중 1개 Samsung Instinct Camera Replacement: 13 단계, 이미지 2개 중 2개
      • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
      댓글 쓰기
    5. Samsung Instinct Camera Replacement: 14 단계, 이미지 1개 중 1개
      • Lift the motherboard away from the front casing.
      댓글 쓰기
    6. Samsung Instinct Camera Replacement: 15 단계, 이미지 1개 중 1개
      • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
      댓글 쓰기
    1. Samsung Instinct Camera Replacement, Motherboard: 16 단계, 이미지 3개 중 1개 Samsung Instinct Camera Replacement, Motherboard: 16 단계, 이미지 3개 중 2개 Samsung Instinct Camera Replacement, Motherboard: 16 단계, 이미지 3개 중 3개
      • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
      • There are three strips total: one on the right, left, and top of the phone.
      댓글 쓰기
    2. Samsung Instinct Camera Replacement: 17 단계, 이미지 1개 중 1개
      • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
      댓글 쓰기
    3. Samsung Instinct Camera Replacement: 18 단계, 이미지 1개 중 1개
      • Using the plastic opener tool, remove the speaker from its setting.
      • Pry where the wire enters the speaker.
      • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
      댓글 쓰기
    4. Samsung Instinct Camera Replacement: 19 단계, 이미지 1개 중 1개
      • Gently lift the motherboard from the center frame.
      댓글 쓰기
    1. Samsung Instinct Camera Replacement, Camera: 20 단계, 이미지 1개 중 1개
      • Once the motherboard is removed from the frame, use the pry tool to remove the camera.
      • Insert the pry bar between the camera and the frame then lift up.
      • The camera is held in by adhesive so it will require some force to remove.
      • You have now successfully removed the camera from your Samsung Instinct.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Patrick
회원 가입일: 10/11/11
75 평판
안내서 2개를 작성함
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 회원
CPSU-REGAN-F11S3G13
4 회원들
안내서 96개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 39
전체 시간: 1,258
