주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Instinct Speaker Replacement
필요한 것
  1. Samsung Instinct Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
    댓글 쓰기
  2. Samsung Instinct Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Holding the phone firmly, use the notches to grip and lift up the battery.
    댓글 쓰기
  3. Samsung Instinct Speaker Replacement, Back Case: 3 단계, 이미지 1개 중 1개
    • Remove the four 4.45mm screws at the corners of the phone.
    댓글 쓰기
  4. Samsung Instinct Speaker Replacement: 4 단계, 이미지 2개 중 1개 Samsung Instinct Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
    댓글 쓰기
  5. Samsung Instinct Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the casing off of the phone.
    댓글 쓰기
  6. Samsung Instinct Speaker Replacement, Antenna: 6 단계, 이미지 1개 중 1개
    • With the screws removed, locate the antenna.
    댓글 쓰기
  7. Samsung Instinct Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    댓글 쓰기
  8. Samsung Instinct Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    댓글 쓰기
  9. Samsung Instinct Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift up on the antenna and remove it from the back of the device.
    댓글 쓰기
  10. Samsung Instinct Speaker Replacement, Front Case: 10 단계, 이미지 1개 중 1개
    • Remove the two 3.50mm screws connecting the motherboard to the case.
    댓글 쓰기
  11. Samsung Instinct Speaker Replacement: 11 단계, 이미지 3개 중 1개 Samsung Instinct Speaker Replacement: 11 단계, 이미지 3개 중 2개 Samsung Instinct Speaker Replacement: 11 단계, 이미지 3개 중 3개
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
    댓글 쓰기
  12. Samsung Instinct Speaker Replacement: 12 단계, 이미지 1개 중 1개
    • Lift out the top right ribbon from its slot on the motherboard.
    댓글 쓰기
  13. Samsung Instinct Speaker Replacement: 13 단계, 이미지 2개 중 1개 Samsung Instinct Speaker Replacement: 13 단계, 이미지 2개 중 2개
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
    댓글 쓰기
  14. Samsung Instinct Speaker Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the motherboard away from the front casing.
    댓글 쓰기
  15. Samsung Instinct Speaker Replacement: 15 단계, 이미지 1개 중 1개
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
    댓글 쓰기
  16. Samsung Instinct Speaker Replacement, Speaker: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers to grasp the pins of the speaker, gently lift the speaker up out of its setting in the front case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Brayton
회원 가입일: 10/12/11
49 평판
안내서 2개를 작성함
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 회원
CPSU-REGAN-F11S3G13
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 27
전체 시간: 1,079
