주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Jack LCD Replacement
필요한 것
    1. Samsung Jack LCD Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Slide the battery cover downwards with pressure focused on the center of the cover.
      • Lift the cover off of the phone.
      댓글 쓰기
    2. Samsung Jack LCD Replacement: 2 단계, 이미지 1개 중 1개
      • Grasp the bottom left and right corners of the battery and lift it from its housing.
      댓글 쓰기
    1. Samsung Jack LCD Replacement, Rear Case: 3 단계, 이미지 1개 중 1개
      • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
      댓글 쓰기
    2. Samsung Jack LCD Replacement: 4 단계, 이미지 3개 중 1개 Samsung Jack LCD Replacement: 4 단계, 이미지 3개 중 2개 Samsung Jack LCD Replacement: 4 단계, 이미지 3개 중 3개
      • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool in between the front and rear cases.
      • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
      댓글 쓰기
    3. Samsung Jack LCD Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the rear case off of the phone.
      댓글 쓰기
    1. Samsung Jack LCD Replacement, Antenna: 6 단계, 이미지 1개 중 1개
      • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
      댓글 쓰기
    2. Samsung Jack LCD Replacement: 7 단계, 이미지 3개 중 1개 Samsung Jack LCD Replacement: 7 단계, 이미지 3개 중 2개 Samsung Jack LCD Replacement: 7 단계, 이미지 3개 중 3개
      • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
      • Use a spudger to remove the wire connector under the antenna.
      댓글 쓰기
    1. Samsung Jack LCD Replacement, Speaker: 8 단계, 이미지 1개 중 1개
      • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
      • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
      댓글 쓰기
    2. Samsung Jack LCD Replacement: 9 단계, 이미지 2개 중 1개 Samsung Jack LCD Replacement: 9 단계, 이미지 2개 중 2개
      • Use the spudger to detach the speaker ribbon cable.
      댓글 쓰기
    3. Samsung Jack LCD Replacement: 10 단계, 이미지 1개 중 1개
      • Lift the speaker out of its compartment.
      댓글 쓰기
    1. Samsung Jack LCD Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
      • Remove the power and volume buttons on the right side of the Motherboard.
      댓글 쓰기
    2. Samsung Jack LCD Replacement: 12 단계, 이미지 2개 중 1개 Samsung Jack LCD Replacement: 12 단계, 이미지 2개 중 2개
      • Use a spudger to detach the camera ribbon cable.
      • Lift the camera off of the Motherboard.
      댓글 쓰기
    3. Samsung Jack LCD Replacement: 13 단계, 이미지 2개 중 1개 Samsung Jack LCD Replacement: 13 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
      댓글 쓰기
    4. Samsung Jack LCD Replacement: 14 단계, 이미지 3개 중 1개 Samsung Jack LCD Replacement: 14 단계, 이미지 3개 중 2개 Samsung Jack LCD Replacement: 14 단계, 이미지 3개 중 3개
      • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
      • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
      댓글 쓰기
    5. Samsung Jack LCD Replacement: 15 단계, 이미지 2개 중 1개 Samsung Jack LCD Replacement: 15 단계, 이미지 2개 중 2개
      • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
      • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
      • Use a spudger to disconnect the Motherboard ribbon cable.
      댓글 쓰기
    6. Samsung Jack LCD Replacement: 16 단계, 이미지 1개 중 1개
      • Lift the Motherboard off of the phone.
      댓글 쓰기
    1. Samsung Jack LCD Replacement, LCD: 17 단계, 이미지 3개 중 1개 Samsung Jack LCD Replacement, LCD: 17 단계, 이미지 3개 중 2개 Samsung Jack LCD Replacement, LCD: 17 단계, 이미지 3개 중 3개
      • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
      • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
      댓글 쓰기
    2. Samsung Jack LCD Replacement: 18 단계, 이미지 2개 중 1개 Samsung Jack LCD Replacement: 18 단계, 이미지 2개 중 2개
      • Lift up the LCD frame.
      댓글 쓰기
    3. Samsung Jack LCD Replacement: 19 단계, 이미지 3개 중 1개 Samsung Jack LCD Replacement: 19 단계, 이미지 3개 중 2개 Samsung Jack LCD Replacement: 19 단계, 이미지 3개 중 3개
      • There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
      • Insert the spudger under the bottom left corner of the LCD screen.
      • Use the spudger to gently pry the LCD screen out of its frame.
      • Gently remove the screen from the frame.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Paul Piller
회원 가입일: 04/12/11
56 평판
안내서 5개를 작성함
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G57
4 회원들
안내서 49개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 29
전체 시간: 2,259
