주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung L100 Setting Knob Spring
필요한 것
  1. Samsung L100 Setting Knob Spring, Removing Back Cover: 1 단계, 이미지 3개 중 1개 Samsung L100 Setting Knob Spring, Removing Back Cover: 1 단계, 이미지 3개 중 2개 Samsung L100 Setting Knob Spring, Removing Back Cover: 1 단계, 이미지 3개 중 3개
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
    댓글 쓰기
  2. Samsung L100 Setting Knob Spring: 2 단계, 이미지 2개 중 1개 Samsung L100 Setting Knob Spring: 2 단계, 이미지 2개 중 2개
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
    댓글 쓰기
  3. Samsung L100 Setting Knob Spring: 3 단계, 이미지 3개 중 1개 Samsung L100 Setting Knob Spring: 3 단계, 이미지 3개 중 2개 Samsung L100 Setting Knob Spring: 3 단계, 이미지 3개 중 3개
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
    댓글 쓰기
  4. Samsung L100 Setting Knob Spring: 4 단계, 이미지 1개 중 1개
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
    댓글 쓰기
  5. Samsung L100 Setting Knob Spring: 5 단계, 이미지 1개 중 1개
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
    댓글 쓰기
  6. Samsung L100 Setting Knob Spring, Flash Circuit Board: 6 단계, 이미지 1개 중 1개
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
    댓글 쓰기
  7. Samsung L100 Setting Knob Spring: 7 단계, 이미지 2개 중 1개 Samsung L100 Setting Knob Spring: 7 단계, 이미지 2개 중 2개
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
    댓글 쓰기
  8. Samsung L100 Setting Knob Spring: 8 단계, 이미지 1개 중 1개
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
    댓글 쓰기
  9. Samsung L100 Setting Knob Spring: 9 단계, 이미지 1개 중 1개
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
    댓글 쓰기
  10. Samsung L100 Setting Knob Spring: 10 단계, 이미지 3개 중 1개 Samsung L100 Setting Knob Spring: 10 단계, 이미지 3개 중 2개 Samsung L100 Setting Knob Spring: 10 단계, 이미지 3개 중 3개
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
    댓글 쓰기
  11. Samsung L100 Setting Knob Spring, Setting Knob Spring: 11 단계, 이미지 1개 중 1개
    • Face the bottom of the Flash Circuit board towards you.
    • Remove the one screw that's located on the left side of the lens.
    댓글 쓰기
  12. Samsung L100 Setting Knob Spring: 12 단계, 이미지 1개 중 1개
    • Take the flash circuit board and turn it over.
    • Remove the plastic setting knob.
    • Make sure to keep copper spring inside of the slot.
    댓글 쓰기
  13. Samsung L100 Setting Knob Spring: 13 단계, 이미지 3개 중 1개 Samsung L100 Setting Knob Spring: 13 단계, 이미지 3개 중 2개 Samsung L100 Setting Knob Spring: 13 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Take out and replace the Setting Knob Spring with tweezers.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
andyhe
회원 가입일: 04/15/10
81 평판
안내서 1개를 작성함
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 회원
CPSU-MANESS-S10S6G17
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 54
전체 시간: 3,529
