주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung ML2510 Rear Cooling Fan Replacement
필요한 것
    1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 1개 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 2개 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 3개
      • Remove the top hinged panel by taking out the pins at the bottom of this panel.
      댓글 쓰기
    2. Samsung ML2510 Rear Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
      댓글 쓰기
    3. Samsung ML2510 Rear Cooling Fan Replacement: 3 단계, 이미지 3개 중 1개 Samsung ML2510 Rear Cooling Fan Replacement: 3 단계, 이미지 3개 중 2개 Samsung ML2510 Rear Cooling Fan Replacement: 3 단계, 이미지 3개 중 3개
      • Gently lift the top panel while simultaneously pulling off the back panel.
      • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
      댓글 쓰기
    1. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: 4 단계, 이미지 2개 중 1개 Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: 4 단계, 이미지 2개 중 2개
      • Once the fan is detached, unplug the fan from the circuit board.
      • Slide the fan's wiring through the anchored slit.
      댓글 쓰기
    2. Samsung ML2510 Rear Cooling Fan Replacement: 5 단계, 이미지 1개 중 1개
      • With the new fan, thread the wiring through the old fan's slit.
      • Reconnect the fan by plugging it back into the circuit board.
      • Reattach the back panel following these instructions in reverse order.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
bbaustin
회원 가입일: 10/12/11
268 평판
안내서 6개를 작성함
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 회원
CPSU-REGAN-F11S17G18
4 회원들
안내서 53개를 작성함
1가이드 댓글
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 44
전체 시간: 3,864
