주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung ML2510 Side Cooling Fan Replacement
필요한 것
    1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 1개 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 2개 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 3개
      • Remove the top hinged panel by taking out the pins at the bottom of this panel.
      댓글 쓰기
    2. Samsung ML2510 Side Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
      댓글 쓰기
    3. Samsung ML2510 Side Cooling Fan Replacement: 3 단계, 이미지 3개 중 1개 Samsung ML2510 Side Cooling Fan Replacement: 3 단계, 이미지 3개 중 2개 Samsung ML2510 Side Cooling Fan Replacement: 3 단계, 이미지 3개 중 3개
      • Gently lift the top panel while simultaneously pulling off the back panel.
      • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
      댓글 쓰기
    1. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: 4 단계, 이미지 3개 중 1개 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: 4 단계, 이미지 3개 중 2개 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: 4 단계, 이미지 3개 중 3개
      • Locate the holes on the panel that are attached to the main body.
      • Remove the front panel by gently moving the holes from the pegs one by one.
      댓글 쓰기
    2. Samsung ML2510 Side Cooling Fan Replacement: 5 단계, 이미지 1개 중 1개
      • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
      댓글 쓰기
    3. Samsung ML2510 Side Cooling Fan Replacement: 6 단계, 이미지 3개 중 1개 Samsung ML2510 Side Cooling Fan Replacement: 6 단계, 이미지 3개 중 2개 Samsung ML2510 Side Cooling Fan Replacement: 6 단계, 이미지 3개 중 3개
      • Using a plastic opening tool, gently lift one side of the top panel from its peg.
      • Repeat process for the other side.
      • Lift the top panel from the front to remove it entirely.
      댓글 쓰기
    4. Samsung ML2510 Side Cooling Fan Replacement: 7 단계, 이미지 3개 중 1개 Samsung ML2510 Side Cooling Fan Replacement: 7 단계, 이미지 3개 중 2개 Samsung ML2510 Side Cooling Fan Replacement: 7 단계, 이미지 3개 중 3개
      • Lift the right side-panel up from the raised stops.
      • Gently rotate the panel as indicated in the picture to remove the panel entirely.
      댓글 쓰기
    5. Samsung ML2510 Side Cooling Fan Replacement: 8 단계, 이미지 1개 중 1개
      • Poke out the side fan from the inside of the printer.
      댓글 쓰기
    6. Samsung ML2510 Side Cooling Fan Replacement: 9 단계, 이미지 1개 중 1개
      • Unplug the fan's wires from the side circuit board.
      • Replace the fan and reassemble the printer using reverse procedures.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
bbaustin
회원 가입일: 10/12/11
268 평판
안내서 6개를 작성함
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 회원
CPSU-REGAN-F11S17G18
4 회원들
안내서 53개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 2,957
