주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NP-130-JA01US Keyboard Replacement
필요한 것
  1. Samsung NP-130-JA01US Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
    댓글 쓰기
  2. Samsung NP-130-JA01US Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung NP-130-JA01US Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the left and right slider buttons fully away from each other.
    댓글 쓰기
  3. Samsung NP-130-JA01US Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery out of the computer.
    댓글 쓰기
  4. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Samsung NP-130-JA01US Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
    댓글 쓰기
  5. Samsung NP-130-JA01US Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Samsung NP-130-JA01US Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Samsung NP-130-JA01US Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the computer and open the front cover so that the screen is looking at you.
    • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
    • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
    댓글 쓰기
  6. Samsung NP-130-JA01US Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Samsung NP-130-JA01US Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Samsung NP-130-JA01US Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the keyboard over.
    • Notice the lock mechanism (marked in red) that holds the cables to the computer.
    • With your fingers, flip the mechanism over before pulling the cables out.
    • Second picture shows the unlocked position.
    • Carefully pull the cables out of the computer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alejandro Guerra Piol
회원 가입일: 09/12/16
319 평판
안내서 2개를 작성함
USF Tampa, Team 9-6, Lacy Fall 2016 USF Tampa, Team 9-6, Lacy Fall 2016 회원
USFT-LACY-F16S9G6
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 39
전체 시간: 664
