주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NP-QX411L Screen Replacement
필요한 것
  1. Samsung NP-QX411L Screen Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
    • Flip the laptop over.
    • Remove the 6 mm screw with the Phillips #000 screwdriver.
    댓글 쓰기
  2. Samsung NP-QX411L Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide out the optical drive to remove it.
    댓글 쓰기
  3. Samsung NP-QX411L Screen Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
    댓글 쓰기
  4. Samsung NP-QX411L Screen Replacement: 4 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
    댓글 쓰기
  5. Samsung NP-QX411L Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
    댓글 쓰기
  6. Samsung NP-QX411L Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
    댓글 쓰기
  7. Samsung NP-QX411L Screen Replacement, Hinges: 7 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement, Hinges: 7 단계, 이미지 2개 중 2개
    • Disconnect the wire from the motherboard by pulling up and away from the laptop.
    댓글 쓰기
  8. Samsung NP-QX411L Screen Replacement: 8 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the top two rubber stoppers using precision tweezers.
    댓글 쓰기
  9. Samsung NP-QX411L Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Unscrew nine 6 mm screws on the cover using a Phillips #000 screwdriver.
    댓글 쓰기
  10. Samsung NP-QX411L Screen Replacement: 10 단계, 이미지 3개 중 1개 Samsung NP-QX411L Screen Replacement: 10 단계, 이미지 3개 중 2개 Samsung NP-QX411L Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Wedge the spudger under the cover to gently pry it up.
    댓글 쓰기
  11. Samsung NP-QX411L Screen Replacement: 11 단계, 이미지 3개 중 1개 Samsung NP-QX411L Screen Replacement: 11 단계, 이미지 3개 중 2개 Samsung NP-QX411L Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Disconnect the wire by carefully using the plastic opening tool to pry the connector away from the motherboard.
    댓글 쓰기
  12. Samsung NP-QX411L Screen Replacement: 12 단계, 이미지 3개 중 1개 Samsung NP-QX411L Screen Replacement: 12 단계, 이미지 3개 중 2개 Samsung NP-QX411L Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Use precision tweezers to pop the antenna wires off of the WiFi card.
    댓글 쓰기
  13. Samsung NP-QX411L Screen Replacement: 13 단계, 이미지 3개 중 1개 Samsung NP-QX411L Screen Replacement: 13 단계, 이미지 3개 중 2개 Samsung NP-QX411L Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Open the laptop slightly.
    • Holding the laptop open, remove three 4 mm screws from each hinge (6 total) using a Phillips #000 screwdriver.
    댓글 쓰기
  14. Samsung NP-QX411L Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Hold hinges in place with your thumb and slide the laptop away from the screen.
    댓글 쓰기
  15. Samsung NP-QX411L Screen Replacement: 15 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the 4 rubber stoppers with the precision tweezers.
    댓글 쓰기
  16. Samsung NP-QX411L Screen Replacement: 16 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the four 4 mm screws with a Phillips #000 screwdriver.
    댓글 쓰기
  17. Samsung NP-QX411L Screen Replacement: 17 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement: 17 단계, 이미지 2개 중 2개
    • The metal spudger could scratch the screen.
    • Wedge the metal spudger underneath the cover and run it along the edges. Gently pry the cover up.
    댓글 쓰기
  18. Samsung NP-QX411L Screen Replacement: 18 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement: 18 단계, 이미지 2개 중 2개
    • Remove the three 4 mm screws on each hinge with a Phillips #000 screwdriver. There should be a total of 6 screws to remove.
    댓글 쓰기
  19. Samsung NP-QX411L Screen Replacement, Screen: 19 단계, 이미지 2개 중 1개 Samsung NP-QX411L Screen Replacement, Screen: 19 단계, 이미지 2개 중 2개
    • Remove the four 4 mm screws using Phillips #000 screwdriver.
    • Remove metal brackets.
    댓글 쓰기
  20. Samsung NP-QX411L Screen Replacement: 20 단계, 이미지 1개 중 1개
    • Use the small suction cup to lift the screen.
    • Disconnect the wire by pulling it away from the bottom of the screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Rebecca Johnson
회원 가입일: 02/17/17
594 평판
안내서 5개를 작성함
USF Tampa, Team S19-G3, Hoffman Spring 2017 USF Tampa, Team S19-G3, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 25
전체 시간: 1,418
