주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NP-R540-JA09US Front Panel Replacement
필요한 것
  1. Samsung NP-R540-JA09US Front Panel Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
    댓글 쓰기
  2. Samsung NP-R540-JA09US Front Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the two latches outward.
    댓글 쓰기
  3. Samsung NP-R540-JA09US Front Panel Replacement: 3 단계, 이미지 2개 중 1개 Samsung NP-R540-JA09US Front Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the battery out of the laptop.
    댓글 쓰기
  4. Samsung NP-R540-JA09US Front Panel Replacement, Optical Drive: 4 단계, 이미지 1개 중 1개
    • Remove securing screw with the PH0 head.
    댓글 쓰기
  5. Samsung NP-R540-JA09US Front Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the optical drive out and remove it from the device.
    댓글 쓰기
  6. Samsung NP-R540-JA09US Front Panel Replacement, Keyboard: 6 단계, 이미지 1개 중 1개
    • Remove the two Phillips #0 screws labeled KBD.
    댓글 쓰기
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
    댓글 쓰기
  7. Samsung NP-R540-JA09US Front Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
    댓글 쓰기
  8. Samsung NP-R540-JA09US Front Panel Replacement: 9 단계, 이미지 2개 중 1개 Samsung NP-R540-JA09US Front Panel Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the keyboard cable from the motherboard.
    댓글 쓰기
  9. Samsung NP-R540-JA09US Front Panel Replacement, Front Panel: 10 단계, 이미지 1개 중 1개
    • Remove the two screws with a Phillips #00 screwdriver.
    댓글 쓰기
  10. Samsung NP-R540-JA09US Front Panel Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
    댓글 쓰기
  11. Samsung NP-R540-JA09US Front Panel Replacement: 12 단계, 이미지 3개 중 1개 Samsung NP-R540-JA09US Front Panel Replacement: 12 단계, 이미지 3개 중 2개 Samsung NP-R540-JA09US Front Panel Replacement: 12 단계, 이미지 3개 중 3개
    • Pry the front panel away from the base with an Opening Tool.
    댓글 쓰기
  12. Samsung NP-R540-JA09US Front Panel Replacement: 13 단계, 이미지 2개 중 1개 Samsung NP-R540-JA09US Front Panel Replacement: 13 단계, 이미지 2개 중 2개
    • Disconnect the speaker wire from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Daylyn Bourland
회원 가입일: 09/21/18
297 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 37
전체 시간: 893
