주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NP300E5C Screen Replacement
필요한 것
  1. Samsung NP300E5C Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Lay laptop down so that the bottom is facing the sky.
    댓글 쓰기
  2. Samsung NP300E5C Screen Replacement: 2 단계, 이미지 3개 중 1개 Samsung NP300E5C Screen Replacement: 2 단계, 이미지 3개 중 2개 Samsung NP300E5C Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
    댓글 쓰기
  3. Samsung NP300E5C Screen Replacement, Screen: 3 단계, 이미지 1개 중 1개
    • Turn the laptop over and open it so that you can see the keyboard and screen.
    • Using a Phillips #000 screwdriver, remove the two 4 mm Phillips #8 screws that are under the black covers on the front of your screen.
    • You can remove the black covers by simply pushing your screwdriver into them.
    댓글 쓰기
  4. Samsung NP300E5C Screen Replacement: 4 단계, 이미지 3개 중 1개 Samsung NP300E5C Screen Replacement: 4 단계, 이미지 3개 중 2개 Samsung NP300E5C Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into the seam on the top of the screen.
    • The seam is where the back screen cover and the plastic bezel around the edges of the screen meet.
    • Use the plastic opening tool to pop open the clasps that keep the casing on the screen.
    • It helps to use the plastic opening tool like a crowbar.
    • Follow this seam around the laptop's screen with the plastic opening tool until the plastic cover comes off.
    • Don't be afraid to use your fingers to help pop open the clips.
    댓글 쓰기
  5. Samsung NP300E5C Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #000 screwdriver, remove the top two 4 mm Phillips #8 screws that join the LCD screen to the plastic casing.
    • Using the same screwdriver, remove the bottom four 4 mm Phillips #8 screws that mount the screen onto the base of the laptop.
    • As you remove these bottom 4 screws, support the screen! As the screws come off, the screen will begin to fall backwards.
    댓글 쓰기
  6. Samsung NP300E5C Screen Replacement: 6 단계, 이미지 3개 중 1개 Samsung NP300E5C Screen Replacement: 6 단계, 이미지 3개 중 2개 Samsung NP300E5C Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Gently lay the LCD on the keyboard, and lay down the back panel of the screen as well. They are not attached and will separate easily.
    • The LCD and the back panel must remain close to one another due to the video connector at the bottom that links the two.
    • Remove the tape that secures the video connector to the LCD.
    • While maintaining a firm grip on the LCD, grasp the video connector at its base, and pull it away from you.
    • Don't be afraid to pull, the video connector is not soldered onto the LCD.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
aliahsan95
회원 가입일: 09/23/15
937 평판
안내서 4개를 작성함
Baylor, Team 10-13, Williams Fall 2015 Baylor, Team 10-13, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G13
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 80
전체 시간: 6,774
