주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NP700Z5AH Display Replacement
필요한 것
  1. Samsung NP700Z5AH Display Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
    댓글 쓰기
  2. Samsung NP700Z5AH Display Replacement: 2 단계, 이미지 3개 중 1개 Samsung NP700Z5AH Display Replacement: 2 단계, 이미지 3개 중 2개 Samsung NP700Z5AH Display Replacement: 2 단계, 이미지 3개 중 3개
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
    댓글 쓰기
  3. Samsung NP700Z5AH Display Replacement: 3 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Display Replacement: 3 단계, 이미지 2개 중 2개
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
    댓글 쓰기
  4. Samsung NP700Z5AH Display Replacement: 4 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Display Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
    댓글 쓰기
  5. Samsung NP700Z5AH Display Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
    댓글 쓰기
  6. Samsung NP700Z5AH Display Replacement: 6 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Display Replacement: 6 단계, 이미지 2개 중 2개
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    댓글 쓰기
  7. Samsung NP700Z5AH Display Replacement, Display: 7 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Display Replacement, Display: 7 단계, 이미지 2개 중 2개
    • Place the tip of the spudger under the metal caps of the black and grey coaxial connectors and pry upwards to disconnect them.
    • After they are disconnected, un-thread the coaxial connectors from around the fan.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors "snap" into their sockets much like the metal snaps on a jacket.
    댓글 쓰기
  8. Samsung NP700Z5AH Display Replacement: 8 단계, 이미지 3개 중 1개 Samsung NP700Z5AH Display Replacement: 8 단계, 이미지 3개 중 2개 Samsung NP700Z5AH Display Replacement: 8 단계, 이미지 3개 중 3개
    • Using the Phillips#00, remove the single 3.5mm screw from the wireless card.
    • Grasp the edges of the wireless card with your fingers and pull straight backwards to remove it.
    댓글 쓰기
  9. Samsung NP700Z5AH Display Replacement: 9 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Display Replacement: 9 단계, 이미지 2개 중 2개
    • Using the Phillips#00, remove the six 4.5mm screws from the corner brackets holding the display to the inner case.
    댓글 쓰기
  10. Samsung NP700Z5AH Display Replacement: 10 단계, 이미지 3개 중 1개 Samsung NP700Z5AH Display Replacement: 10 단계, 이미지 3개 중 2개 Samsung NP700Z5AH Display Replacement: 10 단계, 이미지 3개 중 3개
    • Using your fingers, grasp the edges of the inner case then lift and pull away to separate it from the display.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Erik
회원 가입일: 09/27/17
895 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 35
전체 시간: 1,264
