주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NP700Z5AH Hard Drive Replacement
필요한 것
  1. Samsung NP700Z5AH Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
    댓글 쓰기
  2. Samsung NP700Z5AH Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Samsung NP700Z5AH Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Samsung NP700Z5AH Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
    댓글 쓰기
  3. Samsung NP700Z5AH Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
    댓글 쓰기
  4. Samsung NP700Z5AH Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
    댓글 쓰기
  5. Samsung NP700Z5AH Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
    댓글 쓰기
  6. Samsung NP700Z5AH Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    댓글 쓰기
  7. Samsung NP700Z5AH Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 1개 Samsung NP700Z5AH Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 2개 Samsung NP700Z5AH Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 3개
    • Using the tip of the spudger, flip up the small locking flap on the ZIF connector. Now you can pull the cable.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
    댓글 쓰기
  8. Samsung NP700Z5AH Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Using the Phillips#00, remove the four 4.5mm screws securing the hard drive.
    댓글 쓰기
  9. Samsung NP700Z5AH Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 Samsung NP700Z5AH Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Using your fingers, grasp the edges of the hard drive and lift to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Erik
회원 가입일: 09/27/17
895 평판
안내서 6개를 작성함
2가이드 댓글
Thanks, Eric. I wished I’d read your ifixit lesson before I broke it!! Next time I’ll know better.
rbrtparsons - 답글 공유
cảm ơn rất chi tiết
thọ nguyễn văn - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 42
전체 시간: 2,795
