주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX Mini Button Panel Replacement
필요한 것
  1. Samsung NX Mini Button Panel Replacement, Battery: 1 단계, 이미지 3개 중 1개 Samsung NX Mini Button Panel Replacement, Battery: 1 단계, 이미지 3개 중 2개 Samsung NX Mini Button Panel Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
    댓글 쓰기
  2. Samsung NX Mini Button Panel Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX Mini Button Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
    댓글 쓰기
  3. Samsung NX Mini Button Panel Replacement, Front Case: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
    댓글 쓰기
  4. Samsung NX Mini Button Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
    댓글 쓰기
  5. Samsung NX Mini Button Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
    댓글 쓰기
  6. Samsung NX Mini Button Panel Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
    댓글 쓰기
  7. Samsung NX Mini Button Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Use tweezers to remove the inner metal ring.
    댓글 쓰기
  8. Samsung NX Mini Button Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
    댓글 쓰기
  9. Samsung NX Mini Button Panel Replacement: 9 단계, 이미지 2개 중 1개 Samsung NX Mini Button Panel Replacement: 9 단계, 이미지 2개 중 2개
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
    댓글 쓰기
  10. Samsung NX Mini Button Panel Replacement, Sensor: 10 단계, 이미지 3개 중 1개 Samsung NX Mini Button Panel Replacement, Sensor: 10 단계, 이미지 3개 중 2개 Samsung NX Mini Button Panel Replacement, Sensor: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
    댓글 쓰기
  11. Samsung NX Mini Button Panel Replacement: 11 단계, 이미지 2개 중 1개 Samsung NX Mini Button Panel Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
    댓글 쓰기
  12. Samsung NX Mini Button Panel Replacement: 12 단계, 이미지 3개 중 1개 Samsung NX Mini Button Panel Replacement: 12 단계, 이미지 3개 중 2개 Samsung NX Mini Button Panel Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
    댓글 쓰기
  13. Samsung NX Mini Button Panel Replacement: 13 단계, 이미지 2개 중 1개 Samsung NX Mini Button Panel Replacement: 13 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
    댓글 쓰기
  14. Samsung NX Mini Button Panel Replacement: 14 단계, 이미지 1개 중 1개
    • Gently remove the sensor mount from the camera case.
    댓글 쓰기
  15. Samsung NX Mini Button Panel Replacement, Motherboard: 15 단계, 이미지 2개 중 1개 Samsung NX Mini Button Panel Replacement, Motherboard: 15 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
    댓글 쓰기
  16. Samsung NX Mini Button Panel Replacement: 16 단계, 이미지 2개 중 1개 Samsung NX Mini Button Panel Replacement: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to disconnect the wifi antenna from the motherboard.
    댓글 쓰기
  17. Samsung NX Mini Button Panel Replacement: 17 단계, 이미지 3개 중 1개 Samsung NX Mini Button Panel Replacement: 17 단계, 이미지 3개 중 2개 Samsung NX Mini Button Panel Replacement: 17 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the LCD ribbon cable by prying it straight up from the motherboard.
    댓글 쓰기
  18. Samsung NX Mini Button Panel Replacement: 18 단계, 이미지 3개 중 1개 Samsung NX Mini Button Panel Replacement: 18 단계, 이미지 3개 중 2개 Samsung NX Mini Button Panel Replacement: 18 단계, 이미지 3개 중 3개
    • Use a spudger to unlock the topmost ZIF connector by flipping open the black flap.
    댓글 쓰기
  19. Samsung NX Mini Button Panel Replacement: 19 단계, 이미지 2개 중 1개 Samsung NX Mini Button Panel Replacement: 19 단계, 이미지 2개 중 2개
    • Insert the pointed end of a spudger into the hole in the middle of the ribbon cable.
    • Gently pull the spudger back to slide the ribbon cable out of its connector.
    댓글 쓰기
  20. Samsung NX Mini Button Panel Replacement: 20 단계, 이미지 3개 중 1개 Samsung NX Mini Button Panel Replacement: 20 단계, 이미지 3개 중 2개 Samsung NX Mini Button Panel Replacement: 20 단계, 이미지 3개 중 3개
    • Disconnect the blue ribbon cable from the motherboard.
    • Insert the pointed end of a spudger into the hole in the top of the ribbon.
    • Gently pull the ribbon from the connector.
    댓글 쓰기
  21. Samsung NX Mini Button Panel Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the motherboard from the camera.
    댓글 쓰기
  22. Samsung NX Mini Button Panel Replacement, Button Panel: 22 단계, 이미지 1개 중 1개
    • Remove the three 4 mm Phillips #00 screws securing the button panel to the camera case.
    댓글 쓰기
  23. Samsung NX Mini Button Panel Replacement: 23 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to lift the button panel cover away from the case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Kelsea Weber
회원 가입일: 11/12/15
21,442 평판
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 830
