주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX2000 Menu Buttons Replacement
필요한 것
  1. Samsung NX2000 Menu Buttons Replacement, LCD: 1 단계, 이미지 1개 중 1개
    • First begin by flipping your camera upside down.
    • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
    • Remember to store the screws in a secure place.
    댓글 쓰기
  2. Samsung NX2000 Menu Buttons Replacement: 2 단계, 이미지 3개 중 1개 Samsung NX2000 Menu Buttons Replacement: 2 단계, 이미지 3개 중 2개 Samsung NX2000 Menu Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    댓글 쓰기
  3. Samsung NX2000 Menu Buttons Replacement: 3 단계, 이미지 3개 중 1개 Samsung NX2000 Menu Buttons Replacement: 3 단계, 이미지 3개 중 2개 Samsung NX2000 Menu Buttons Replacement: 3 단계, 이미지 3개 중 3개
    • Before taking it apart you'll have to detach the display ribbon cable.
    • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
    댓글 쓰기
  4. Samsung NX2000 Menu Buttons Replacement: 4 단계, 이미지 3개 중 1개 Samsung NX2000 Menu Buttons Replacement: 4 단계, 이미지 3개 중 2개 Samsung NX2000 Menu Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Separate the LCD half compartment of the camera from the main body.
    댓글 쓰기
  5. Samsung NX2000 Menu Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four 1mm screws with the Y0 screwdriver.
    댓글 쓰기
  6. Samsung NX2000 Menu Buttons Replacement: 6 단계, 이미지 3개 중 1개 Samsung NX2000 Menu Buttons Replacement: 6 단계, 이미지 3개 중 2개 Samsung NX2000 Menu Buttons Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
    • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
    댓글 쓰기
  7. Samsung NX2000 Menu Buttons Replacement: 7 단계, 이미지 3개 중 1개 Samsung NX2000 Menu Buttons Replacement: 7 단계, 이미지 3개 중 2개 Samsung NX2000 Menu Buttons Replacement: 7 단계, 이미지 3개 중 3개
    • Place blue plastic spudger in between LCD screen and plastic surrounding.
    • Begin to lift up slowly, removing the LCD screen from the main frame.
    댓글 쓰기
  8. Samsung NX2000 Menu Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • The LCD screen is now separated form the main frame.
    댓글 쓰기
  9. Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 9 단계, 이미지 3개 중 1개 Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 9 단계, 이미지 3개 중 2개 Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the tweezers to pull out the home and playback buttons from the camera frame.
    댓글 쓰기
  10. Samsung NX2000 Menu Buttons Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the home buttons from the camera frame.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Katarina Raic
회원 가입일: 02/09/16
288 평판
안내서 2개를 작성함
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 회원
USFT-CHENG-S16S7G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 740
