주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX300 Rear Menu Button Replacement
필요한 것
    1. Samsung NX300 Rear Menu Button Replacement, Unscrew the Back Panel: 1 단계, 이미지 2개 중 1개 Samsung NX300 Rear Menu Button Replacement, Unscrew the Back Panel: 1 단계, 이미지 2개 중 2개
      • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
      • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
      댓글 쓰기
    2. Samsung NX300 Rear Menu Button Replacement, Remove the Input Port Screw: 2 단계, 이미지 1개 중 1개
      • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
      댓글 쓰기
    3. Samsung NX300 Rear Menu Button Replacement, Open the Camera Casing: 3 단계, 이미지 3개 중 1개 Samsung NX300 Rear Menu Button Replacement, Open the Camera Casing: 3 단계, 이미지 3개 중 2개 Samsung NX300 Rear Menu Button Replacement, Open the Camera Casing: 3 단계, 이미지 3개 중 3개
      • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
      댓글 쓰기
    4. Samsung NX300 Rear Menu Button Replacement, Remove the Back Panel: 4 단계, 이미지 3개 중 1개 Samsung NX300 Rear Menu Button Replacement, Remove the Back Panel: 4 단계, 이미지 3개 중 2개 Samsung NX300 Rear Menu Button Replacement, Remove the Back Panel: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
      • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
      댓글 쓰기
    1. Samsung NX300 Rear Menu Button Replacement, Remove the LCD Screen: 5 단계, 이미지 3개 중 1개 Samsung NX300 Rear Menu Button Replacement, Remove the LCD Screen: 5 단계, 이미지 3개 중 2개 Samsung NX300 Rear Menu Button Replacement, Remove the LCD Screen: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Using a Phillips #00 precision screwdriver, remove the four 1mm screws that are holding the black supports to the panel.
      • Remove the little ribbon tab from the contact pad using tweezers or your fingers, then peel off the black ribbon from the metallic panel.
      • Feed the ribbon through the slot on the back panel to free the LCD Screen. You need to bend the ribbon to get the small tabs through it.
      댓글 쓰기
    2. Samsung NX300 Rear Menu Button Replacement, Remove the Metallic Panel: 6 단계, 이미지 2개 중 1개 Samsung NX300 Rear Menu Button Replacement, Remove the Metallic Panel: 6 단계, 이미지 2개 중 2개
      • Using a Phillips #00 precision screwdriver, remove the five 3mm screws.
      • Using a plastic opening tool, slowly lift up the entire metal piece from the back of the camera.
      • If the panel has never been removed from the camera before, it will be glued firmly to the back panel and will require some force to remove. To prevent breaking the back panel, work the plastic opening tool under different areas of the metal plate until it is completely released.
      • There are two small magnetic blocks housed underneath the metallic plate. These are for securing the swivel screen in place while it is closed.
      댓글 쓰기
    3. Samsung NX300 Rear Menu Button Replacement, Remove the Menu Buttons: 7 단계, 이미지 3개 중 1개 Samsung NX300 Rear Menu Button Replacement, Remove the Menu Buttons: 7 단계, 이미지 3개 중 2개 Samsung NX300 Rear Menu Button Replacement, Remove the Menu Buttons: 7 단계, 이미지 3개 중 3개
      • Once you remove the metallic panel, peel off the black pad from the buttons using tweezers.
      • Using tweezers, remove any button you need to by pulling on the plastic strips near the connection point to the back panel.
      • If most of the menu buttons need to be replaced, it is better to replace all of the buttons, since the plastic connector pieces break easily during removal.
      댓글 쓰기
    4. Samsung NX300 Rear Menu Button Replacement, Free Buttons: 8 단계, 이미지 1개 중 1개
      • The menu buttons are now free from the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andres Perez
회원 가입일: 01/21/15
1,023 평판
안내서 5개를 작성함
USF Tampa, Team 9-6, Blackwell Winter 2015 USF Tampa, Team 9-6, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G6
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 25
전체 시간: 1,851
