주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX500 Image Sensor Replacement
필요한 것
    1. Samsung NX500 Image Sensor Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung NX500 Image Sensor Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Pull the switch on the bottom of the camera back with your thumb.
      댓글 쓰기
    2. Samsung NX500 Image Sensor Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX500 Image Sensor Replacement: 2 단계, 이미지 2개 중 2개
      • Push second switch(blue) forward with your thumb.
      댓글 쓰기
    3. Samsung NX500 Image Sensor Replacement: 3 단계, 이미지 1개 중 1개
      • Pull out battery.
      댓글 쓰기
    1. Samsung NX500 Image Sensor Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 1개 Samsung NX500 Image Sensor Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 2개 Samsung NX500 Image Sensor Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 3개
      • Open the screen exposing the hinge cover and place the plastic opening tool inside.
      • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
      • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
      댓글 쓰기
    2. Samsung NX500 Image Sensor Replacement: 5 단계, 이미지 3개 중 1개 Samsung NX500 Image Sensor Replacement: 5 단계, 이미지 3개 중 2개 Samsung NX500 Image Sensor Replacement: 5 단계, 이미지 3개 중 3개
      • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
      • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
      • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
      • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
      댓글 쓰기
    3. Samsung NX500 Image Sensor Replacement: 6 단계, 이미지 2개 중 1개 Samsung NX500 Image Sensor Replacement: 6 단계, 이미지 2개 중 2개
      • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
      • The casing should be removed easily; you shouldn't have to use much force.
      댓글 쓰기
    4. Samsung NX500 Image Sensor Replacement: 7 단계, 이미지 2개 중 1개 Samsung NX500 Image Sensor Replacement: 7 단계, 이미지 2개 중 2개
      • Locate the black ribbon at the bottom left of the camera's interior.
      • Place the plastic opening tool under the black ribbon connector.
      • Remove the cable by moving your plastic opening tool in a downward motion.
      • There is zero to little force needed to remove this ribbon.
      댓글 쓰기
    1. Samsung NX500 Image Sensor Replacement, Main board: 8 단계, 이미지 3개 중 1개 Samsung NX500 Image Sensor Replacement, Main board: 8 단계, 이미지 3개 중 2개 Samsung NX500 Image Sensor Replacement, Main board: 8 단계, 이미지 3개 중 3개
      • Lift the black latch of the left main ribbon connector using a wide-set plastic opening tool in a downward motion.
      • Use your fingers to disconnect the cable.
      • There are five ZIF cables total to be removed.
      댓글 쓰기
    2. Samsung NX500 Image Sensor Replacement: 9 단계, 이미지 3개 중 1개 Samsung NX500 Image Sensor Replacement: 9 단계, 이미지 3개 중 2개 Samsung NX500 Image Sensor Replacement: 9 단계, 이미지 3개 중 3개
      • Use the wide-set plastic opening tool to lift the latch on the right main ZIF cable in a downward motion.
      • Disconnect the cable using your finger.
      댓글 쓰기
    3. Samsung NX500 Image Sensor Replacement: 10 단계, 이미지 2개 중 1개 Samsung NX500 Image Sensor Replacement: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Locate the ZIF cable at the bottom of the main board.
      • Disconnect the cable with the tweezers by pulling it away from where the cable is connected.
      • Be careful not tug too hard on the cable as you can damage it.
      댓글 쓰기
    4. Samsung NX500 Image Sensor Replacement: 11 단계, 이미지 2개 중 1개 Samsung NX500 Image Sensor Replacement: 11 단계, 이미지 2개 중 2개
      • Locate the skinny ZIF cable on the left side of the main board.
      댓글 쓰기
    5. Samsung NX500 Image Sensor Replacement: 12 단계, 이미지 3개 중 1개 Samsung NX500 Image Sensor Replacement: 12 단계, 이미지 3개 중 2개 Samsung NX500 Image Sensor Replacement: 12 단계, 이미지 3개 중 3개
      • Locate the black cable connected at the top right of the main board.
      • Place the wide-set plastic opening tool underneath the gray connector and carefully pry it up.
      • It will easily pop up.
      댓글 쓰기
    6. Samsung NX500 Image Sensor Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the 4 black 4-mm Phillips #000 screws located near each corner of the main board.
      • Lift the board out of the casing and carefully put it somewhere safe.
      댓글 쓰기
    1. Samsung NX500 Image Sensor Replacement, Image Sensor: 14 단계, 이미지 2개 중 1개 Samsung NX500 Image Sensor Replacement, Image Sensor: 14 단계, 이미지 2개 중 2개
      • Remove the three black 5-mm T6 type screws using a Torx screwdriver located along the metal casing of the image sensor.
      • The image sensor is very sensitive, be sure not to smudge the filter covering.
      • Pull the image sensor out and it can now be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eli Carcalete
회원 가입일: 09/15/16
599 평판
안내서 4개를 작성함
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G5
3 회원들
안내서 12개를 작성함
3가이드 댓글
Thanks for this, very helpfull.
I needed to replace the shutter assembly.
For this, next step is to remove the metal top of the camera (a screw on each side and 2 screws in the flash shoe below the spring).
After this the 2 screws on top of the shutter assembly can be removed.
The shutter assy can now be removed although it is somewhat easier if the tripod mount is removed first.
Piet van der Plas - 답글 공유
Very helpful. Thanks for posting.
My mode selector is not changing mode as it should, it seems like a contact failure. What shoul I do?
Juan Prekop
prekop - 답글 공유
thanks so much for sharing Well appreciated
dave_tjeng - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 28
전체 시간: 2,528
