주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX500 Main board Replacement
필요한 것
    1. Samsung NX500 Main board  Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung NX500 Main board  Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Pull the switch on the bottom of the camera back with your thumb.
      댓글 쓰기
    2. Samsung NX500 Main board  Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX500 Main board  Replacement: 2 단계, 이미지 2개 중 2개
      • Push second switch(blue) forward with your thumb.
      댓글 쓰기
    3. Samsung NX500 Main board  Replacement: 3 단계, 이미지 1개 중 1개
      • Pull out battery.
      댓글 쓰기
    1. Samsung NX500 Main board  Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 1개 Samsung NX500 Main board  Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 2개 Samsung NX500 Main board  Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 3개
      • Open the screen exposing the hinge cover and place the plastic opening tool inside.
      • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
      • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
      댓글 쓰기
    2. Samsung NX500 Main board  Replacement: 5 단계, 이미지 3개 중 1개 Samsung NX500 Main board  Replacement: 5 단계, 이미지 3개 중 2개 Samsung NX500 Main board  Replacement: 5 단계, 이미지 3개 중 3개
      • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
      • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
      • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
      • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
      댓글 쓰기
    3. Samsung NX500 Main board  Replacement: 6 단계, 이미지 2개 중 1개 Samsung NX500 Main board  Replacement: 6 단계, 이미지 2개 중 2개
      • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
      • The casing should be removed easily; you shouldn't have to use much force.
      댓글 쓰기
    4. Samsung NX500 Main board  Replacement: 7 단계, 이미지 2개 중 1개 Samsung NX500 Main board  Replacement: 7 단계, 이미지 2개 중 2개
      • Locate the black ribbon at the bottom left of the camera's interior.
      • Place the plastic opening tool under the black ribbon connector.
      • Remove the cable by moving your plastic opening tool in a downward motion.
      • There is zero to little force needed to remove this ribbon.
      댓글 쓰기
    1. Samsung NX500 Main board  Replacement, Main board: 8 단계, 이미지 3개 중 1개 Samsung NX500 Main board  Replacement, Main board: 8 단계, 이미지 3개 중 2개 Samsung NX500 Main board  Replacement, Main board: 8 단계, 이미지 3개 중 3개
      • Lift the black latch of the left main ribbon connector using a wide-set plastic opening tool in a downward motion.
      • Use your fingers to disconnect the cable.
      • There are five ZIF cables total to be removed.
      댓글 쓰기
    2. Samsung NX500 Main board  Replacement: 9 단계, 이미지 3개 중 1개 Samsung NX500 Main board  Replacement: 9 단계, 이미지 3개 중 2개 Samsung NX500 Main board  Replacement: 9 단계, 이미지 3개 중 3개
      • Use the wide-set plastic opening tool to lift the latch on the right main ZIF cable in a downward motion.
      • Disconnect the cable using your finger.
      댓글 쓰기
    3. Samsung NX500 Main board  Replacement: 10 단계, 이미지 2개 중 1개 Samsung NX500 Main board  Replacement: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Locate the ZIF cable at the bottom of the main board.
      • Disconnect the cable with the tweezers by pulling it away from where the cable is connected.
      • Be careful not tug too hard on the cable as you can damage it.
      댓글 쓰기
    4. Samsung NX500 Main board  Replacement: 11 단계, 이미지 2개 중 1개 Samsung NX500 Main board  Replacement: 11 단계, 이미지 2개 중 2개
      • Locate the skinny ZIF cable on the left side of the main board.
      댓글 쓰기
    5. Samsung NX500 Main board  Replacement: 12 단계, 이미지 3개 중 1개 Samsung NX500 Main board  Replacement: 12 단계, 이미지 3개 중 2개 Samsung NX500 Main board  Replacement: 12 단계, 이미지 3개 중 3개
      • Locate the black cable connected at the top right of the main board.
      • Place the wide-set plastic opening tool underneath the gray connector and carefully pry it up.
      • It will easily pop up.
      댓글 쓰기
    6. Samsung NX500 Main board  Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the 4 black 4-mm Phillips #000 screws located near each corner of the main board.
      • Lift the board out of the casing and carefully put it somewhere safe.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Eli Carcalete
회원 가입일: 09/15/16
599 평판
안내서 4개를 작성함
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G5
3 회원들
안내서 12개를 작성함
5가이드 댓글
How do you actually get the mainboard for replacement? Is it directly through Samsung?
Andrew Bydlon - 답글 공유
Nevermind, the parts are available at Samsungparts.com.
I believe the particular part of interest is the AD92-02282A, although I'll write a followup if this is not correct.
I can now confirm the part is the AD92-02282A. Following this guide worked very well and saved me risking $800 on ebay for a used nx500.
i’ve been told that after replacing the mainboard the camera needs to be adjusted which could only be done by a professional workshop.
did you run into any problems with the new mainboard?
Christoph Bresch - 답글 공유
Where to get or address to obtain or purchase new board for replacement?
Bay publicity & Multimedia - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 34
전체 시간: 2,245
