주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX500 Screen Side Encasement Replacement
필요한 것
    1. Samsung NX500 Screen Side Encasement Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Pull the switch on the bottom of the camera back with your thumb.
      댓글 쓰기
    2. Samsung NX500 Screen Side Encasement Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 2 단계, 이미지 2개 중 2개
      • Push second switch(blue) forward with your thumb.
      댓글 쓰기
    3. Samsung NX500 Screen Side Encasement Replacement: 3 단계, 이미지 1개 중 1개
      • Pull out battery.
      댓글 쓰기
    1. Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 1개 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 2개 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 3개
      • Open the screen exposing the hinge cover and place the plastic opening tool inside.
      • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
      • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
      댓글 쓰기
    2. Samsung NX500 Screen Side Encasement Replacement: 5 단계, 이미지 3개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 5 단계, 이미지 3개 중 2개 Samsung NX500 Screen Side Encasement Replacement: 5 단계, 이미지 3개 중 3개
      • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
      • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
      • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
      • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
      댓글 쓰기
    3. Samsung NX500 Screen Side Encasement Replacement: 6 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 6 단계, 이미지 2개 중 2개
      • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
      • The casing should be removed easily; you shouldn't have to use much force.
      댓글 쓰기
    4. Samsung NX500 Screen Side Encasement Replacement: 7 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 7 단계, 이미지 2개 중 2개
      • Locate the black ribbon at the bottom left of the camera's interior.
      • Place the plastic opening tool under the black ribbon connector.
      • Remove the cable by moving your plastic opening tool in a downward motion.
      • There is zero to little force needed to remove this ribbon.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
carter grenewicz
회원 가입일: 09/15/16
204 평판
안내서 2개를 작성함
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G5
3 회원들
안내서 16개를 작성함
1가이드 댓글
your dumb. idot
Nick Furio - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 1,431
