주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Refrigerator Control Board Replacement
필요한 것
  1. Samsung Refrigerator Control Board Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    댓글 쓰기
  2. Samsung Refrigerator Control Board Replacement, Remove the board access panel: 2 단계, 이미지 1개 중 1개
    • Remove the screws securing the board access panel to the back of the refrigerator.
    댓글 쓰기
  3. Samsung Refrigerator Control Board Replacement: 3 단계, 이미지 2개 중 1개 Samsung Refrigerator Control Board Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the board access panel.
    댓글 쓰기
  4. Samsung Refrigerator Control Board Replacement, Reassembly information: 4 단계, 이미지 2개 중 1개 Samsung Refrigerator Control Board Replacement, Reassembly information: 4 단계, 이미지 2개 중 2개
    • Note the locations and number of the connectors on the control board, and photograph them or draw a diagram. This example control board has nine wire connectors:
    • Three connectors along the top edge
    • One connector along the right edge
    • One connector along the bottom edge
    • Four connectors along the left edge
    • During reassembly, use your diagram or the photo you took (like the second image here) to make sure you've reconnected all of the connectors.
    댓글 쓰기
  5. Samsung Refrigerator Control Board Replacement, Remove the control board: 5 단계, 이미지 2개 중 1개 Samsung Refrigerator Control Board Replacement, Remove the control board: 5 단계, 이미지 2개 중 2개
    • Pull and disconnect each of the connectors from the control board.
    • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
    • Move the wires away from the control board so it can swing out of its recess.
    댓글 쓰기
  6. Samsung Refrigerator Control Board Replacement: 6 단계, 이미지 3개 중 1개 Samsung Refrigerator Control Board Replacement: 6 단계, 이미지 3개 중 2개 Samsung Refrigerator Control Board Replacement: 6 단계, 이미지 3개 중 3개
    • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
    • Swing the control board out and remove it.
    댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers Community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,140 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,437개를 작성함
5가이드 댓글
My tempura in my new refrigerator isn’t working right , I bought earlier this year
Carolyn whittaker - 답글 공유
Is this Samsung
Do you have a phone number
Samsung fridge- after changing a water filter, bottom drawer freezer stopped making ice.
It is set for 0 but no ice. I bought this fridge last year.
Sewell Nikki - 답글 공유
My refrigerator light is on but the comppresor is not working and anytime I on it is not piping sounds again
Asiafa - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 84
지난 30일: 399
전체 시간: 8,940
