주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Refrigerator Control Panel Replacement
필요한 것
    1. Samsung Refrigerator Control Panel Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      댓글 쓰기
    1. Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 1개 Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 2개
      • Open both French doors for the refrigerator compartment.
      댓글 쓰기
    1. Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 3 단계, 이미지 3개 중 1개 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 3 단계, 이미지 3개 중 2개 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 3 단계, 이미지 3개 중 3개
      • The control panel has plastic clips around its perimeter that secure it to the refrigerator wall.
      • Insert a spudger into the seam along the right edge of the control panel.
      • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
      • Press the spudger in firmly and pry to loosen the panel.
      • Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
      댓글 쓰기
    2. Samsung Refrigerator Control Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Flip the control panel over to reveal the cable connector.
      댓글 쓰기
    3. Samsung Refrigerator Control Panel Replacement: 5 단계, 이미지 2개 중 1개 Samsung Refrigerator Control Panel Replacement: 5 단계, 이미지 2개 중 2개
      • Use your fingers to slide the cable connector out of its socket.
      댓글 쓰기
    4. Samsung Refrigerator Control Panel Replacement, Remove the control panel: 6 단계, 이미지 1개 중 1개
      • Remove the control panel.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers Community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,990 평판
안내서 89개를 작성함
Team Vulcan Team Vulcan 회원
Staff
6 회원들
안내서 898개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 74
지난 30일: 279
전체 시간: 4,814
