주요 콘텐츠로 건너뛰기
Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker)
필요한 것
  1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: 2 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: 2 단계, 이미지 2개 중 2개
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: 3 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: 3 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: 3 단계, 이미지 3개 중 3개
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: 4 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: 4 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: 4 단계, 이미지 3개 중 3개
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 5 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 5 단계, 이미지 2개 중 2개
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: 6 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: 6 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
  7. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: 7 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: 7 단계, 이미지 2개 중 2개
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
  8. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 8 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 8 단계, 이미지 2개 중 2개
    • Use your fingers to guide the wire harness out of the icemaker assembly.
  9. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 9 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 9 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 9 단계, 이미지 3개 중 3개
    • Squeeze the icemaker cable connector and pull to disconnect it.
  10. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): 10 단계, 이미지 1개 중 1개
    • Remove the icemaker assembly.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
313,339 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,735개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 52
전체 시간: 1,449
