주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Refrigerator Icemaker Assembly Replacement
필요한 것
  1. Samsung Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    댓글 쓰기
  2. Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 2개
    • Open both French doors for the refrigerator compartment.
    댓글 쓰기
  3. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 3 단계, 이미지 1개 중 1개
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
    댓글 쓰기
  4. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 4 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 4 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 4 단계, 이미지 3개 중 3개
    댓글 쓰기
  5. Samsung Refrigerator Icemaker Assembly Replacement, Check the ice bucket condition: 5 단계, 이미지 1개 중 1개
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
    댓글 쓰기
  6. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: 6 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: 6 단계, 이미지 2개 중 2개
    • Remove the wire harness screw securing the cable cover panel.
    댓글 쓰기
  7. Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 7 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 7 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 7 단계, 이미지 3개 중 3개
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
    댓글 쓰기
  8. Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: 8 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: 8 단계, 이미지 2개 중 2개
    • The exact configuration of the connectors may vary on your refrigerator.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with your fingers.
    • Rock the connector gently side to side to disconnect it.
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
    댓글 쓰기
  9. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: 9 단계, 이미지 1개 중 1개
    • Remove the ice maker screw securing the air tunnel flap.
    댓글 쓰기
  10. Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 10 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 10 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 10 단계, 이미지 3개 중 3개
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
    댓글 쓰기
  11. Samsung Refrigerator Icemaker Assembly Replacement: 11 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
    댓글 쓰기
  12. Samsung Refrigerator Icemaker Assembly Replacement: 12 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
    댓글 쓰기
  13. Samsung Refrigerator Icemaker Assembly Replacement: 13 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement: 13 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Assembly Replacement: 13 단계, 이미지 3개 중 3개
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
    댓글 쓰기
  14. Samsung Refrigerator Icemaker Assembly Replacement: 14 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
    댓글 쓰기
  15. Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: 15 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: 15 단계, 이미지 2개 중 2개
    댓글 쓰기
결론
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,990 평판
안내서 89개를 작성함
Team Vulcan Team Vulcan 회원
Staff
6 회원들
안내서 306개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 51
지난 7일: 305
지난 30일: 1,213
전체 시간: 26,980
