주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Rogue Keyboard Replacement
필요한 것
  1. Samsung Rogue Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
    댓글 쓰기
  2. Samsung Rogue Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • You can now remove the battery by prying it up with your finger.
    댓글 쓰기
  3. Samsung Rogue Keyboard Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
    댓글 쓰기
  4. Samsung Rogue Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
    댓글 쓰기
  5. Samsung Rogue Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Samsung Rogue Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Samsung Rogue Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
    댓글 쓰기
  6. Samsung Rogue Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 3.45 mm Philips screws below the white sticker.
    댓글 쓰기
  7. Samsung Rogue Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
    댓글 쓰기
  8. Samsung Rogue Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to disconnect the film from the motherboard.
    댓글 쓰기
  9. Samsung Rogue Keyboard Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Remove the eight 1.7mm Philips screws above the keyboard.
    댓글 쓰기
  10. Samsung Rogue Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully remove keyboard holder from the slider mechanisms underneath.
    댓글 쓰기
  11. Samsung Rogue Keyboard Replacement: 11 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Viktoria Mikoultchik
회원 가입일: 04/15/12
25 평판
안내서 7개를 작성함
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 회원
CPSU-MANESS-S12S7G32
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 605
