주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung S85 Battery Door Replacement
필요한 것
    1. Samsung S85 Battery Door Replacement, Battery Door: 1 단계, 이미지 3개 중 1개 Samsung S85 Battery Door Replacement, Battery Door: 1 단계, 이미지 3개 중 2개 Samsung S85 Battery Door Replacement, Battery Door: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Rotate camera such that battery door is facing upwards. Open battery as if you normally would when changing batteries
      • Bend paperclip such that metal is now a thin rod
      • Align rod portion of paperclip with pin located at bottom of battery door. Gently push on pin with rod such that rod replaces pin underneath battery door as shown in first picture
      • Be careful with spring located with pin as this may fly off when being pushed out by paperclip.
      • Using tweezers, gently pull pin out from opposite end of paperclip. When pin is fully removed, remove paper clip.
      • Battery door should now be fully removed from battery slot.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 44
전체 시간: 1,270
