주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung S85 Rubber Door Replacement
필요한 것
    1. Samsung S85 Rubber Door Replacement, Rubber Door: 1 단계, 이미지 3개 중 1개 Samsung S85 Rubber Door Replacement, Rubber Door: 1 단계, 이미지 3개 중 2개 Samsung S85 Rubber Door Replacement, Rubber Door: 1 단계, 이미지 3개 중 3개
      • Remove 4 screws from bottom of camera
      • Remove 2 screws from side of camera
      • Place Screws on magnetic surface or location where they will not roll away
      댓글 쓰기
    2. Samsung S85 Rubber Door Replacement: 2 단계, 이미지 1개 중 1개
      • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
      댓글 쓰기
    3. Samsung S85 Rubber Door Replacement: 3 단계, 이미지 2개 중 1개 Samsung S85 Rubber Door Replacement: 3 단계, 이미지 2개 중 2개
      • Remove 6 screws identified by red circles
      • Remove 3 screws identified by orange circles
      댓글 쓰기
    4. Samsung S85 Rubber Door Replacement: 4 단계, 이미지 2개 중 1개 Samsung S85 Rubber Door Replacement: 4 단계, 이미지 2개 중 2개
      • Gently remove orange circuit ribbon identified by red square
      • Gently remove narrow orange circuit ribbon identified by blue square
      댓글 쓰기
    5. Samsung S85 Rubber Door Replacement: 5 단계, 이미지 3개 중 1개 Samsung S85 Rubber Door Replacement: 5 단계, 이미지 3개 중 2개 Samsung S85 Rubber Door Replacement: 5 단계, 이미지 3개 중 3개
      • Be very cautious when using a soldering iron (they are on average 300 F)
      • Using a soldering iron, remove solder from wire identified by red circle
      • Using a soldering iron, remove solder from black and red wire identified by orange circle
      • Using a soldering iron, remove solder from wire identified by yellow circle
      댓글 쓰기
    6. Samsung S85 Rubber Door Replacement: 6 단계, 이미지 3개 중 1개 Samsung S85 Rubber Door Replacement: 6 단계, 이미지 3개 중 2개 Samsung S85 Rubber Door Replacement: 6 단계, 이미지 3개 중 3개
      • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
      • Repeat step two to three times until board feels flexible to bend
      • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
      댓글 쓰기
    7. Samsung S85 Rubber Door Replacement: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove black rubber door located on side of camera closest to lens using tweezers.
      • Be careful not to bend or tear the rubber when pulling out with tweezers as it may become difficult to put back in
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 32
전체 시간: 730
