주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SCH-3500 Back Cover Replacement
필요한 것
    1. Samsung SCH-3500 Back Cover Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung SCH-3500 Back Cover Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
      댓글 쓰기
    2. Samsung SCH-3500 Back Cover Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
      댓글 쓰기
    3. Samsung SCH-3500 Back Cover Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the battery away from the phone case.
      댓글 쓰기
    1. Samsung SCH-3500 Back Cover Replacement, Antenna: 4 단계, 이미지 2개 중 1개 Samsung SCH-3500 Back Cover Replacement, Antenna: 4 단계, 이미지 2개 중 2개
      • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
      댓글 쓰기
    2. Samsung SCH-3500 Back Cover Replacement: 5 단계, 이미지 1개 중 1개
      • When unscrewed, pull the antenna straight up and out.
      댓글 쓰기
    3. Samsung SCH-3500 Back Cover Replacement: 6 단계, 이미지 2개 중 1개 Samsung SCH-3500 Back Cover Replacement: 6 단계, 이미지 2개 중 2개
      • Pull the guide tube free from its retaining ring and slide it out the top.
      댓글 쓰기
    1. Samsung SCH-3500 Back Cover Replacement, Back Cover: 7 단계, 이미지 1개 중 1개
      • Remove the four screws using a T6 Torx screwdriver.
      댓글 쓰기
    2. Samsung SCH-3500 Back Cover Replacement: 8 단계, 이미지 2개 중 1개 Samsung SCH-3500 Back Cover Replacement: 8 단계, 이미지 2개 중 2개
      • Work from the bottom of the phone, separating the two halves of the case.
      • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
      댓글 쓰기
    3. Samsung SCH-3500 Back Cover Replacement: 9 단계, 이미지 1개 중 1개
      • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
      • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
      댓글 쓰기
    4. Samsung SCH-3500 Back Cover Replacement: 10 단계, 이미지 3개 중 1개 Samsung SCH-3500 Back Cover Replacement: 10 단계, 이미지 3개 중 2개 Samsung SCH-3500 Back Cover Replacement: 10 단계, 이미지 3개 중 3개
      • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
      • The Back Cover is now removed. Congratulations.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brett Tomashitis
회원 가입일: 03/09/12
36 평판
안내서 5개를 작성함
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 회원
CLEM-BENSON-S12S2G6
2 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 909
