주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SCH-3500 Key Pad Replacement
필요한 것
    1. Samsung SCH-3500 Key Pad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung SCH-3500 Key Pad Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
      댓글 쓰기
    2. Samsung SCH-3500 Key Pad Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
      댓글 쓰기
    3. Samsung SCH-3500 Key Pad Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the battery away from the phone case.
      댓글 쓰기
    1. Samsung SCH-3500 Key Pad Replacement, Antenna: 4 단계, 이미지 2개 중 1개 Samsung SCH-3500 Key Pad Replacement, Antenna: 4 단계, 이미지 2개 중 2개
      • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
      댓글 쓰기
    2. Samsung SCH-3500 Key Pad Replacement: 5 단계, 이미지 1개 중 1개
      • When unscrewed, pull the antenna straight up and out.
      댓글 쓰기
    3. Samsung SCH-3500 Key Pad Replacement: 6 단계, 이미지 2개 중 1개 Samsung SCH-3500 Key Pad Replacement: 6 단계, 이미지 2개 중 2개
      • Pull the guide tube free from its retaining ring and slide it out the top.
      댓글 쓰기
    1. Samsung SCH-3500 Key Pad Replacement, Back Cover: 7 단계, 이미지 1개 중 1개
      • Remove the four screws using a T6 Torx screwdriver.
      댓글 쓰기
    2. Samsung SCH-3500 Key Pad Replacement: 8 단계, 이미지 2개 중 1개 Samsung SCH-3500 Key Pad Replacement: 8 단계, 이미지 2개 중 2개
      • Work from the bottom of the phone, separating the two halves of the case.
      • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
      댓글 쓰기
    3. Samsung SCH-3500 Key Pad Replacement: 9 단계, 이미지 1개 중 1개
      • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
      • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
      댓글 쓰기
    4. Samsung SCH-3500 Key Pad Replacement: 10 단계, 이미지 3개 중 1개 Samsung SCH-3500 Key Pad Replacement: 10 단계, 이미지 3개 중 2개 Samsung SCH-3500 Key Pad Replacement: 10 단계, 이미지 3개 중 3개
      • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
      • The Back Cover is now removed. Congratulations.
      댓글 쓰기
    1. Samsung SCH-3500 Key Pad Replacement, Logic Board: 11 단계, 이미지 1개 중 1개
      • Remove the connector for the earpiece speaker, located on the upper end of the logic board.
      댓글 쓰기
    2. Samsung SCH-3500 Key Pad Replacement: 12 단계, 이미지 1개 중 1개
      • Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
      댓글 쓰기
    3. Samsung SCH-3500 Key Pad Replacement: 13 단계, 이미지 2개 중 1개 Samsung SCH-3500 Key Pad Replacement: 13 단계, 이미지 2개 중 2개
      • Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered.
      • The logic board is now removed from the phone. Congratulations.
      댓글 쓰기
    1. Samsung SCH-3500 Key Pad Replacement, Key Pad: 14 단계, 이미지 2개 중 1개 Samsung SCH-3500 Key Pad Replacement, Key Pad: 14 단계, 이미지 2개 중 2개
      • Turn the front cover over and shake the keys out of it. They should come free in a single piece.
      • Note: The keypad may accidentally come free while removing rear cover or logic board. It is best to remove the logic board to reinstall the key mat.
      • The key pad is now removed from the phone. Congratulations.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Brett Tomashitis
회원 가입일: 03/09/12
36 평판
안내서 5개를 작성함
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 회원
CLEM-BENSON-S12S2G6
2 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 30
전체 시간: 1,136
