주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SCH-8500 Keypad Replacement
필요한 것
  1. Samsung SCH-8500 Keypad Replacement, Battery: 1 단계, 이미지 3개 중 1개 Samsung SCH-8500 Keypad Replacement, Battery: 1 단계, 이미지 3개 중 2개 Samsung SCH-8500 Keypad Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
    댓글 쓰기
  2. Samsung SCH-8500 Keypad Replacement, Back Case: 2 단계, 이미지 3개 중 1개 Samsung SCH-8500 Keypad Replacement, Back Case: 2 단계, 이미지 3개 중 2개 Samsung SCH-8500 Keypad Replacement, Back Case: 2 단계, 이미지 3개 중 3개
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
    댓글 쓰기
  3. Samsung SCH-8500 Keypad Replacement, Volume Button: 3 단계, 이미지 3개 중 1개 Samsung SCH-8500 Keypad Replacement, Volume Button: 3 단계, 이미지 3개 중 2개 Samsung SCH-8500 Keypad Replacement, Volume Button: 3 단계, 이미지 3개 중 3개
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
    댓글 쓰기
  4. Samsung SCH-8500 Keypad Replacement, Keypad: 4 단계, 이미지 3개 중 1개 Samsung SCH-8500 Keypad Replacement, Keypad: 4 단계, 이미지 3개 중 2개 Samsung SCH-8500 Keypad Replacement, Keypad: 4 단계, 이미지 3개 중 3개
    • The circuit board is hardwired to other components in the phone and cannot be completely removed. Take extreme precaution when performing this step as to not damage the circuitry or the wiring.
    • Lift the circuit board up slightly.
    • With the circuit board lifted, remove the plastic keypad and place to the side.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Will Gunter
회원 가입일: 10/23/12
1 평판
안내서 4개를 작성함
Clemson, Team 14-6, Benson Fall 2012 Clemson, Team 14-6, Benson Fall 2012 회원
CLEM-BENSON-F12S14G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 25
전체 시간: 636
