주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SGH-A137 Keypad Replacement
필요한 것
    1. Samsung SGH-A137 Keypad Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use your thumbs to pull down on the back cover to remove it and expose the battery.
      댓글 쓰기
    2. Samsung SGH-A137 Keypad Replacement: 2 단계, 이미지 1개 중 1개
      • Locate the indent in the case below the battery. (see red square)
      • Place your finger at the indent and pull up on the battery to remove it.
      댓글 쓰기
    1. Samsung SGH-A137 Keypad Replacement, Motherboard: 3 단계, 이미지 3개 중 1개 Samsung SGH-A137 Keypad Replacement, Motherboard: 3 단계, 이미지 3개 중 2개 Samsung SGH-A137 Keypad Replacement, Motherboard: 3 단계, 이미지 3개 중 3개
      • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
      댓글 쓰기
    2. Samsung SGH-A137 Keypad Replacement: 4 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, gently pry open the back of the phone at the seam.
      • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
      댓글 쓰기
    3. Samsung SGH-A137 Keypad Replacement: 5 단계, 이미지 2개 중 1개 Samsung SGH-A137 Keypad Replacement: 5 단계, 이미지 2개 중 2개
      • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
      • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
      댓글 쓰기
    4. Samsung SGH-A137 Keypad Replacement: 6 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, gently pry up the motherboard.
      • You might need to pry from several different locations to get the motherboard loose enough to remove.
      댓글 쓰기
    1. Samsung SGH-A137 Keypad Replacement, Keypad: 7 단계, 이미지 1개 중 1개
      • Gently push the keypad out toward the back.
      댓글 쓰기
    2. Samsung SGH-A137 Keypad Replacement: 8 단계, 이미지 1개 중 1개
      • Replace the defective keypad and reassemble the phone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Gayle Eberhardt Mitchell
회원 가입일: 09/04/15
652 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G1
5 회원들
안내서 50개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 650
