주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SGH-X495 Screen Replacement
필요한 것
  1. Samsung SGH-X495 Screen Replacement, Backplate: 1 단계, 이미지 1개 중 1개
    • Remove the 4 (4.7mm) philips head screws.
    댓글 쓰기
  2. Samsung SGH-X495 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Unplug the rubber charger outlet cover.
    댓글 쓰기
  3. Samsung SGH-X495 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Unplug the rubber headset jack cover.
    댓글 쓰기
  4. Samsung SGH-X495 Screen Replacement: 4 단계, 이미지 2개 중 1개 Samsung SGH-X495 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
    댓글 쓰기
  5. Samsung SGH-X495 Screen Replacement: 5 단계, 이미지 2개 중 1개 Samsung SGH-X495 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
    댓글 쓰기
  6. Samsung SGH-X495 Screen Replacement, Face Plate: 6 단계, 이미지 1개 중 1개
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
    댓글 쓰기
  7. Samsung SGH-X495 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
    댓글 쓰기
  8. Samsung SGH-X495 Screen Replacement: 8 단계, 이미지 2개 중 1개 Samsung SGH-X495 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
    댓글 쓰기
  9. Samsung SGH-X495 Screen Replacement: 9 단계, 이미지 2개 중 1개 Samsung SGH-X495 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
    댓글 쓰기
  10. Samsung SGH-X495 Screen Replacement: 10 단계, 이미지 2개 중 1개 Samsung SGH-X495 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
    댓글 쓰기
  11. Samsung SGH-X495 Screen Replacement, Screen: 11 단계, 이미지 1개 중 1개
    • Use an opening tool to gently lift the ribbon wire connection to the screen.
    댓글 쓰기
  12. Samsung SGH-X495 Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Pull back the protective sticker to open access through the phones joint.
    댓글 쓰기
  13. Samsung SGH-X495 Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Carefully feed ribbon wire through the phones joint.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matthew Hove
회원 가입일: 01/05/11
1,031 평판
안내서 10개를 작성함
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011 회원
CPSU-REGAN-W11S3G40
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 32
전체 시간: 1,662
