주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SPEX SCH-R210 Keypad Replacement
필요한 것
    1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
      • Lay the phone on its front side so the back is visible.
      • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
      • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
      • Slide the cover down from the phone to remove it. Set the cover aside.
      댓글 쓰기
    1. Samsung SPEX SCH-R210 Keypad Replacement, Battery: 2 단계, 이미지 1개 중 1개
      • Locate the access notch at the end of the battery compartment.
      댓글 쓰기
    2. Samsung SPEX SCH-R210 Keypad Replacement: 3 단계, 이미지 1개 중 1개
      • Place your thumb on the edge of the battery near the access notch.
      • Lift the battery to remove it from the phone. Set the battery aside.
      댓글 쓰기
    1. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: 4 단계, 이미지 2개 중 1개 Samsung SPEX SCH-R210 Keypad Replacement, Keypad: 4 단계, 이미지 2개 중 2개
      • Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Samsung SPEX SCH-R210 Keypad Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the headphone cover from the left side of the midframe.
      댓글 쓰기
    3. Samsung SPEX SCH-R210 Keypad Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the volume cover from the right side of the midframe.
      댓글 쓰기
    4. Samsung SPEX SCH-R210 Keypad Replacement: 7 단계, 이미지 1개 중 1개
      • Use your hands to separate the midframe from the rest of the phone.
      • This may take a little effort to remove.
      댓글 쓰기
    5. Samsung SPEX SCH-R210 Keypad Replacement: 8 단계, 이미지 1개 중 1개
      • Use a 1.5 mm hex screwdriver to remove the three 2.4 mm screws around the motherboard.
      댓글 쓰기
    6. Samsung SPEX SCH-R210 Keypad Replacement: 9 단계, 이미지 1개 중 1개
      • Lift the metal plate off of the motherboard and set it aside.
      댓글 쓰기
    7. Samsung SPEX SCH-R210 Keypad Replacement: 10 단계, 이미지 2개 중 1개 Samsung SPEX SCH-R210 Keypad Replacement: 10 단계, 이미지 2개 중 2개
      • Push on the white plastic tabs and the keypad at the same time to remove the motherboard.
      댓글 쓰기
    8. Samsung SPEX SCH-R210 Keypad Replacement: 11 단계, 이미지 2개 중 1개 Samsung SPEX SCH-R210 Keypad Replacement: 11 단계, 이미지 2개 중 2개
      • Turn the phone over to its front side.
      • Apply pressure on the keypad.
      • The keypad will come out easily.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Susan
회원 가입일: 07/11/13
331 평판
안내서 3개를 작성함
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G4
3 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 648
