주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SPEX SCH-R210 antenna Replacement
필요한 것
  1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    댓글 쓰기
  2. Samsung SPEX SCH-R210 antenna Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Locate the access notch at the end of the battery compartment.
    댓글 쓰기
  3. Samsung SPEX SCH-R210 antenna Replacement: 3 단계, 이미지 1개 중 1개
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    댓글 쓰기
  4. Samsung SPEX SCH-R210 antenna Replacement, Antenna: 4 단계, 이미지 2개 중 1개 Samsung SPEX SCH-R210 antenna Replacement, Antenna: 4 단계, 이미지 2개 중 2개
    • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
    댓글 쓰기
  5. Samsung SPEX SCH-R210 antenna Replacement: 5 단계, 이미지 2개 중 1개 Samsung SPEX SCH-R210 antenna Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
    댓글 쓰기
  6. Samsung SPEX SCH-R210 antenna Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
    댓글 쓰기
  7. Samsung SPEX SCH-R210 antenna Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
    댓글 쓰기
  8. Samsung SPEX SCH-R210 antenna Replacement: 8 단계, 이미지 1개 중 1개
    • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
    댓글 쓰기
  9. Samsung SPEX SCH-R210 antenna Replacement: 9 단계, 이미지 1개 중 1개
    • Replace with a new antenna.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Susan
회원 가입일: 07/11/13
331 평판
안내서 3개를 작성함
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G4
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 19
전체 시간: 539
